  On 16/10/2011 at 11:10 AM, n15m0 said:
Thanks. Yeah not sure if I will continue to whore wheels after this!
19x8.5 +25
19x9.5 +30
Wish I can slam it further but mrs would kill me.
Might go and buy a sortaflush sticker :)
Looks tops man! I hope I packed them well ;)
19x8.5 +25
19x9.5 +30
That looks seriously good!!
Are the back tyres thicker than the front? It looks like the front is lower, but not sure.
Thanks. Yeah fronts are 245/35 and rears are 275/35 so yes, rears are a slightly taller profile. Ideally the fronts should be 245/40, but the tires came with the wheels so I will use them until they run out before changing.
It's been a long time since i took some photos of my car. So me and my new house mate cleaned our cars and went for a drive and got some nice shots :thumbsup:
The first place we took phots was at the "Sydney Memorial" Then it was out to the light house (my other house mate said it looked like a cock and balls) :/
After the cock and balls shot we drove around the corner to "Separation Point" for some sunset shots. My fav photo is the one with my car by it's self, LOOKS GREAT :thumbsup:
  On 23/10/2011 at 11:49 AM, scarf said:
this is a very nice shot
Agreed. :thumbsup:
Looking good there, Paul. When you getting new wheels, mate? I think it's long overdue. :)
Edited by VNS 24
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
