  • 3 weeks later...
Same ^
did it the day I got the car and just painted the trim clip silver for the bottom mounting point
Saw a boss looking back coupe with tinted tails on step lip meshies in campbelltown As I was towing my s14 home, you on here?
^ im finally noticed haha thanks mate that was me I seen someone honkin and giving me the thumbs up, then realised it was you with the s14 as you have it on your dp! Lol
Chucked my sexy new 19" inch Koya wheels on the other day. 275 rear goodness.
Just waiting for my new electric blue Akebono big brake kit and then all that's left is my new high flow cats in and I will be finished!
Those big 14inch rotors will fill in the space beautifully.
ENJOY!
1048691_10151654067394411_260497929_o.jp
1025506_10151654068204411_531867365_o.jp
1014565_10151654067809411_1498531145_o.j
1048871_10151654069354411_1929430191_o.j
1049102_10151654069784411_445123441_o.jp
  • Like 1
Yeah your dead right mate. I just never knew what option to take. Needed some help.
Just sitting up at mount lofty. Took her for 15 minutes of spirited handling ....im in love. Havent done it for so long. Forgot what I was missing.
ENJOY!
nice wheels :P
Err maybe it was a new Infinity??
I went and hassled the Infinity sales man on the weekend (parked my v35 out front on a Saturday lol) asking him how they go selling against the import skylines. He was cool, but said that people who are considering these cars at 70k have no idea they can buy an import for less.....it's not in their consideration set. Then went in about warranty, English menus, etc etc
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
