Having read your blog. Welcome to the slammed family with your BC coilovers. How are speed bumps feeling? :no: I'm really struggling. Have to pass them very slowly and sort of diagonal way. Some of them cause ugly scratchings especially ones at the Tea Tree Plaza parking.
Cheers for reading my blog MDCAT, believe it or not - I actually didn't realise my V36 was lowered until it arrived at compliance and even then when I was looking at it... I thought it looked odd (as in, my car looked 'too good' stock, or so I thought hehe) and it was only then when my compliancer showed me, that I realised... "how cool is this" :D
PS: My compliancer later corrected himself (after the blog post, and once he had completed compliance on my V36 Skyline - It actually has Tanabe Sustec Pro S-OC Adjustable Coilover Suspension.
In regards to the ride, it's great! Handles well, firm - yet soft and absorbing of all bumps on the road. I still am aware of spoon drains / road humps / driveways... but even lowered (adjusted at compliance a little higher to ensure legality) my car has no clearance issues - and I'm super comfortable driving - already drove for 2 hours straight around Adelaide - no issues!
I have new tyres lined up (Achilles ATR Sport 2) and I'm getting a service and wheel balance as well, so I'm looking forward to seeing the difference that makes.
Edited by Sikahalv
Yeah. I have no big issues with my car lowered. Handling is sharp and still soft. But be aware that it is a deceiving feeling. I realized that first when scratched at passing a pretty wide speed bump. Just bought a couple of wrenches but have now time to lift her up a bit.
Edited by MDCAT
You are lucky that the compliance workshop had some oem spring/shocks to chuck in it for compliance! When I brought my old R34 4 door in around 10 years ago (when they were quite rare) I couldn't find some stock 4 door suspension (nor a stock exhaust) for some 6 months. So it had to sit in my backyard waiting on those parts before I could send it to compliance (which was here in Adelaide luckily)!
No. Kidding. I know!
Very lucky :yes:
PS: Created a new post for a Vxx Series Meet in Adelaide :whistling:
Edited by Sikahalv
Nice.
Dang it I have been looking at that one for a while and the price was exceptional ... I just wasn't ready to pull the trigger yet. I was hoping it would still be sitting around later in the year, but knew it would sell at that price. Nice buy
  • Like 1
Nice.
...but Andrew... your V35 is stunning! Why......
It's done 162k kms now mate - still as reliable as ever and goes like clockwork, but I use it daily for work and can't ever afford to have it off the road. I am just a tiny bit concerned that into the future it may need more maintenance etc and cause me problems. That said, there is nothing to indicate any faults - it still runs like the day I got it nearly 6 years ago with 48k on the clock!
Then every time I start to get a bit bored of it and think of changing over I will have someone come up to me at a servo or out the front of their house at a valuation and gush over how much they love it - that sort of reminds me that I still love her and that I am not done with her yet :)
Imagine what they'd say if you owned my 50th Anniversary Limited Edition PV36 ;)
Absolutely no offense meant mate, but if I had a V36 sedan they would likely not batt an eyelid at it, as everyone thinks they are fwd Maximas :) .... one of the reasons I have resisted going sedan - imho they just look too pedestrian for me. :whistling:
But seriously, does it get a lot of attention?
It's a bit like why I could never own a Toyota Mark X (even though I like them a lot) - your average Joe Blow just thinks they are Camrys, and I couldn't deal with that :)
    • have you rotated the car yet? if so how smooth was it?
    • And finally, I had the driver's side airbox off while adding a long drain hose under the oil can to down near the oil filter. Doesn't look good, it has definitely had an turbo oil seal leak and looks like it has been for a long time.....guess I'll have to get a pair of highflows to put on the shelf It's also worth mentioning it has a really strange clamp between the bottom of the airflow meter (which has a big barb/lip on it) and the intake pipe. I've used the magic of MSPaint to show, basically you have to clip out those 2 steel springs which unlocks the hose from the AFM. I used 2 flat screwdrivers, the spring sort of clips into the unlocked position. Reassembly you just pop them both back flat once the hose is far enough up the AFM that the spring clamp is above the barb. Weird to use but much more convenient once your'e used to it compared to trying to do up a hose clamp under the airbox like on 32 GTR
    • The other thing I started was a fire extinguisher bracket.  As with a few other cars previously (350z, Leaf), I'm going to add a bracket between the navigator seat's front bolts, then mount the extinguisher on that. Unfortunately Nissan (probably the same engineer who did the A/T fluid interwarmer) decided that the front seat brackets would be recessed and uneven so the bracket shape was a bit tricky; I ended up doing 1 part under each seat mount (the large hole is because there is a flange under the seat mount to allow for the carpet thickness)   and then a horizontal part between those 2 No final pic yet as the paint needs to dry, I'll post up once that's done
    • OK, a few half jobs on the skyline this weekend because its booked for a test day at Wakefield Park on 27-Feb. While the Ecutek dongle and app provide display and logging of a heap of engine parameters, they annoyingly don't have access to the auto trans temp. So I grabbed an oil temp gauge from Raceworks which apparently has warning colour change and peak hold, about $95  and their 8mm hose sender adapter Now, I foolishly thought these 2 might work together, but no, the sender needs about 30mm clearance in the fitting and the adapter only had about 8mm. I've cobbled something together with an NPT T piece and blank for now but will try and work out something more permanent as I intend to use the same fitting for the data logger in the future. Under the car, Nissan's engineers decided that only one opportunity for coolant and trans fluid to mix (the radiator) was not enough, and they also added an interwarmer near the sump on the passenger side like the engine oil has: I've cut the hose between the auto trans outlet and the interwarmer inlet and inserted the sender there as that gives the best indication of temp inside the transmission.   From there it is back to the pain of running that sender wire to the cabin, I've run it up near the passenger headlight, into the battery box, across the channel at the back and into the master cylinder area where I ran out of wire length (and patience). Remainder of the job is through the grommet near the accelerator pedal that I've used previously, then across under the dash to where I will temporarily mount it on the console for track days (and remove it other times). The gauge will also need IGN, BAT and earth (I'm not going to worry about illumination as I'll unhook it between track days)
    • This piece is obscenely discontinued. I honestly hate the frameless window design because the rubber gets stressed and the guides as well every time you open and close the door.
