cheers mate
no doubt i'll give you a wave if I see your ride around as I haven't seen any lakeshore blue v35's either. i don't tend to see many v35 sedan's come to think of it.
i probably won't be lowering it anymore as it's already scraping over speedbumps...i wince in pain every time i drive over any surface that isn't level.
hey guys.. finally upgraded from the 34.. although i miss all the power !.. mines a dec 05 premiem spec.. already removed are the factory alarm sensors on dash , toll card reader , and a few silly things...
Mods done - X force cat back 2 1/3" mendral bent exhaust same as 350z except it needs 25cm added to extend it
full nismo kit from japland
20 x10 with 275 rear and 20x 8.5 235 front koya visso, viper pager alarm
Next to come once chris rodgers has converted my bose dash unit a full 7k stereo and some springs to level the car out..
See you fello skyline owners around
Edited by 53XYN
very nice ride you have here, very beautiful, and beautifully kept.
Your project, should you choose.......let's get that rear number plate nice and straight......??? :P
ps...I just came from an R33.....sure I miss the launch/noise of that thing....but not the 'power' as such...V35 has so much more low-down torque that it made my R33 feel a bit 'small'......I can leave my V35 in 3rd gear most of the time! (and I live in the hills)...R33 was always wanting gears...(still loved it though)
Got dish?
Geeesh!...they are horn looking cars.
I like your dish....(got dosh?)...
They're not overboard, which many seem to be going towards,..I like them very muchly.
Our cars look the same, except mine hasn't got that front wheel mud guard thang....(and got std 18" rims, which I love too muchly to swap over).
Hi all: I'm not new to the site: have been floating around in the Stagea section for quite a while now...
I bought a pair of manual V35s close to 7 months ago: one sensible car, and one silly car. They are now, finally, complied!
As I am yet to take pics of the sensible one (haven't had a chance to clean it yet!)here is the silly car: it is the Chargespeed workshop car for Tokyo Auto Salon '07. It won a trophy in the 'sporty car' category for its body kit. The car is factory standard mechanically, with the exception of the 19" wheels and Advance coilovers, so it's a complete show pony as-is. I intend to keep this one (i think), and add the HKS supercharger kit, for a bit m ore poke. Also, the carbon fibre seats are a new lesson in torture (made for narrow japanese rear ends), but I have a pair of Recaros lying around that I was going top put in the Stagea, so I am considering fitting these after a retrim.
Alternatively, I could put the SC kit on the other car, which is immaculate, and only has 10800km on the clock.... I'm torn! The wife says I have to sell at least one of them, but I don't know which way to go.
Anyway, here's some pics of the kitted car finally in Australia and complied:
As soon as I have it on the road, and cleaned, I'll post some of the other (sensible) car as well...
  • 3 weeks later...
  • 3 weeks later...
    • Clutch done also about a year ago got a DCS HD Single Plate. Basically done everything but touch the engine 🤣 But will definitely get a fuel pump and ECU, then start saving 🫡
    • Fuel pump and clutch and ecu that’ll get you to about 230 or so kw, after that the sky’s the limit and the budget blows out faster then you can blink
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
