  • 4 weeks later...
Here is my BOY. I just love it. I was actually planning to buy a coupe, but couldnot find one at that time. :thumbsup:
Welcome to SAU, Ahmet.
Sedans are a good choice too, more convenient daliy-drive. :)
hey people seen all the other v35's on this forum i think they are all fantastic. Just wanted to show u my v35.
post-80033-0-52856800-1298374271_thumb.jpgpost-80033-0-32025500-1298374367_thumb.jpgpost-80033-0-31425600-1298374443_thumb.jpgpost-80033-0-21832200-1298374571_thumb.jpgpost-80033-0-76150700-1298374696_thumb.jpg
Welcome to SAU, Rob.
Very JDM! :) Are all the black parts wrapped or painted?
Edited by Victor.T
Hey Liner
Can you tell me where did you got your Volk GTC and are they face 1 fronts and face 2 backs.
What are the offset and are they 19 x 8.5 front and 19 x 10.5 rear and with 245 front tires and 275 rear tires
Thanks for the info..
If you ordered them from Japan can you tell the importer and if here in Oz which company
Pics here haha
5522771136_94f30d2a84_b.jpg'
Whilst I like the overall look of this car, I completely don't get why people would lower a car so much to get the mean stance - but then paint the bottom 10+cm of the car the same colour as the road so it actually looks like the car is riding high like a 4wd. Just don't get it. It's like on R34GTRs I love the front and rear lips colour coded to the car (rather than black), so they LOOK really low, as well as actually BEING really low .... my 2c
Ah if it is carbon then all is forgiven :)
And yes Paul, black cars NEVER look as low as they really are sadly (and I would know - I own one). I scrape on every single speed hump and spoon drain, yet my car still doesn't look as low as I would like it - whereas my old pewter S15 wasn't even that low, yet looked slammed. But that is black cars for you!
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to move wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
