Thanks FoxV35,
Yeah, a few mates and myself decided to drive down to the Grand Pacific Drive as none of us had seen the Bridge before. We drove through the Royal National Park to get there, was a fantastic drive.
How'd you guess? :P The first two photos were from a quick stop in the RNP and the third photo was on the South side of the bridge.
Thanks FoxV35,
How'd you guess? :D The first two photos were from a quick stop in the RNP and the third photo was on the South side of the bridge.
haha. i used to play around with my old car in RNP, so i kinda know, but we usually go at night time, didn't know it looks so nice in day time. haha~ don't 4get to ask me to go wif u guys nx time~ lol
FoxV35, will do! I don't go often, that was the first time! That road through the National Park was such a nice drive. Apparently a lot of motor cycles go through there and there are a number of them that come off their bikes due to them pushing to hard around the corners.
Ogz, the RNP is south of Sydney, it's on the Alternate (scenic) route to Wollongong. You can locate it by looking for Loftus in Whereis.com.au or Google maps. One of the entrances to the RNP is off Princes Hwy, called Farnell Avenue. If you plan to stop in there, you have to pay at the front gate, but if you're just passing through, then it's free.
Nice, looks like you got the full nismo kit and also nismo exhaust. Score!
Nice! My exact twin in Adelaide!
There's no distinct difference in noise between the NISMO and the normal stock exhaust...though it gets more growly if more throttle is applied. Maybe it's just mine but there's also no difference when toggling the exhaust switch between the "sport" and "silent" modes..
No it's not exactly a Nismo edition, nor the body kit being a Nismo. It's officially known as the Nissan aero kit, a factory option I believe. :D The exhaust is known as V.S.S - Variable Sports Exhaust, another factory option. It's a bit difficult finding more information about it though.
The switch is located on the lower left dash, below the steering wheel (at the same height where the VDC/boot switch are, but on the left side of the steering wheel instead of right-if that makes sense).
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
