Since i have imported my 2000 rs4 (approx 9months) the head lights have been extreamly poor. Car arrived with 10000k hid's which i have recently changed to 4300k. Much much better although i am finding they adjustment is out. There are 2 adjustments on the lights and i find one moves the beam up and down. the other im not sure. When i more the beam up and down i hear what sounds like an electronic motor move at the same time.
Anyone had experiece adjusting these lights ?
Cheers
Justin
https://www.sau.com.au/forums/topic/233302-stagea-head-lights/
to the right of the steering wheel column, on the dash under the guage cluster. (next to the ignition)
its a dial thing with a picture of a 'light' with numbers above....
its dark atm so i dont have a pic
Edited by Silhouette31
duz any one have the button next to this? i do its a little windscreen with a light on it ? ive never known what it does???
I have not seen it but some one the other day mention that they have a "Winter Edition" which included a heated front windscreen. Is it possible for that?
Cheers
Andy
Cheers
Andy
Hi,now that I see this question...next to the switch for the lights possition ,I have another switch with the image of the windscreen?never had a clue what is it for...until now ,so it could be t heat the windscreen?not having manuals is driving me crazy... :P
That button could possibly be for lowering the headlights beam during towing. Some cars have the function that lowers the angle of the beam so that when the arse end is pulled down from the weight of towing you can lower the level of your headlight beam so as not to affect oncoming cars. Just a thought. (Not to sure)
my manual has a picture of that button and a picture of a dotted line accross the bottom and up the drivers side of the windscreen . i also have the switch in my car . havent had time to figure out exactly what it does /how it works . mind you i have treated my windows to scott goggle cleaner/anti fog . fark it is mint . windows are crystal clear and wont fog up even if you breath right on it
the light adjustments is for teh angle ..as everyone has been saying .. the motor sounds is there motors moving ... park behind a car at night with your lights on .. stay a few car back tho and adjust 1 level and a time .. u will notice it ... and i have the windscreen thing too .. i thort it was auto washer ... nearly hit a parked car trying it out lol ... so i guess its not for auto washer .. im getting my manual in maybe 1week or 2 from www.jpnz.co.nz hopfully its in there ... if its heated screen wicked ...!
stagea's didn't come from the factory with a towing option. as some of the others have said, i have herd of a winter option pack which included heated windscreen wipers, to make it easier to clear the snow and frost away i guess. the button beside the headlight adjustment could be for this?
ahh nice i have this ..... this might save me some time going back inside to get the kettle on those days i take it to work. damn 530am morning's!
wasn't sure if you were joking but I thought I'd follow this up with a warning for anyone who thought pouring boiling water on a frozen windscreen is a good idea.
If you were to pour boiling water on a very cold windscreen, your next problem could be sourcing a completely new windscreen and finding a way to clean all of the cracked bits of glass off your dash and in your air vents etc...
Fortunately I haven't done this but I have heard of it happening 1st hand from several people who have...
I'm sure they all thought AFTERWARDS about how silly an idea it was...but yeah - just a warning to all - if you're gonna pour water on your windscreen to defrost it etc, make sure its COLD WATER or at least only very slightly warm :D
Maybe newer windscreens are stronger these days, but I'm still not willing to chance it...
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
