Since spending a small fortune collecting parts ive now decided what I am and arent using.
Everything is in good working order photos will go up latter
Weaver 4 stage Dry sump pump. Apparently rebuilt before I purchased. Has been stripped down and inspected by westend after I received it. Was given the all good but Im not using it.
Comes with a few -12 fittings as well $450
RB26 Sump, has been modified to suit a dry sump. Pan has been cut and shortened, side wings cut off and plated, 3 -12 fittings welded into the side and internal baffles etc all welded in
I have made another with an extra baffle etc so using this instead $500
Bracket to suit a 5stage peterson pump. Also fits the above weaver pretty well. I made it from steel as a prototype but now machining up a replica from billet so the steel one wont be used. Nothing wrong with it I just wanted a billet one instead. $150
Will put up more latter with photos
Edited by Risking
https://www.sau.com.au/forums/topic/233304-dry-sump-rb26-parts/
  • 1 year later...
Hi, I am planning to put a petersom 5 stage ( roller bearings ) dry sump to a RB26 track engine. Very interested in your left overs. would like to go further either buying your prototypes. please call/sms me on 0439 818008 or 0433 878 905 to follow up.please get some photos. email [email protected]
cheers
Alex
  • 7 months later...
Very old thread but is that Weaver pump still around? Has it been used since that original post was put up?
    • Hey everyone!!  I've noticed that whenever I do my oil changes, after putting 4L in, the oil level sits at the top mark in the dipstick. This is after letting the old oil drain for a very long time too! I've checked the oil level daily for the past few mornings. It happens every time and it's confusing because all the threads say that it should take about 4.7L (With some just adding the full 5L) My next thought is to figure out if the dipstick I have is correct so could someone please tell me the length of the RB25DET engine oil dipstick?  I've checked images of some of the genuine dipsticks, but none of them have the length in it. https://justjap.com/products/genuine-nissan-engine-oil-level-dipstick-fits-nissan-r34-skyline-c34-stagea-c35-laurel-y34-cedric-gloria-rb25de-t-neo?currency=AUD&srsltid=AfmBOortQXofgmiHVRKuIaiKuygL4k0Ewp68c3isGZk0vvKOJ7Yqf3iB However.... the engraving on the genuine ones say 05002 while mine says AA000. This makes me believe that maybe I have a wrong dipstick? I just want to confirm before I buy a new one. The car is a fresh import from Japan so I don't have details of the previous owner to ask him. Thanks in advance 🙏🏾
    • Sport. I didn’t rebleed it cause I just removed the slave and left connected.    I will change line and slave and see how it goes.
    • Oh and how is the rattle when foot is on the clutch ?
    • Did you get the sport or track ? From what the documentation says the uniclutch has a small amount of movement to disengage.  So your story of tricky pedal setup seems common.    Hopefully you got it bled up too, as the bite point moving around is usually either plates wearing in or air in the line.
    • There's always "MIG it up and grind it back".
