Friday 26th September
Meet: Chatswood Chase Car Park, Enter off Victoria Ave
Time: 9:00pm, Leave by 9:30pm
Destination: Palm Beach via Newport for Pizza.
Bring: CB's, a full tank of fuel and a good attitude.
As always, don't do anything silly as we are on public roads.
YOU WILL BE REPORTED TO POLICE - this is NOT a joke
Pizza Place:
Lucky's Pep's Pizza Bar
Shp2/ 303 Barrenjoey Rd Newport 2106 (02) 9979 1756
Here's the list.. (no maybes here kthnx)
Marsss
Sl!m
DRD-00F
msnismo
Anna34
S13Deviat
D_I_F
Cassbo
SHANE666
PORTS
Goldzilla
Bakes
Xmetal
Kujotk
Blitz
Miss Turbo
FloydWestwood
GimpyDammit
LOOF
HOT_R33
Ari25t
v_s_p_e_c
Haysey
Primordial
https://www.sau.com.au/forums/topic/233356-who-wants-p-i-z-z-a/
  • Replies 115
    • From my bolts, standard M8 with 1.25mm thread pitch (M8x1.25mm).    Length is 19mm under the head and has a captive 18mm OD flat washer.   20mm length from a bolt shop is what you'll be able to get.   Make sure they're zinc plated.    If you're concerned about strength, grade 8.8 will be more than enough. Original PN is 01121-04971.  Now discontinued according to Amayama but that's because it's one of the parts that's been captured by the Heritage program, which explains the ridiculous price.   New PN is 01121-RHR20: https://nismodirect.com/nismo-heritage-bolt-pin-hinge-hood-bnr32-nissan-skyline-gt-r-01121-rhr20-01121-04971/ About AUD33 converted from Yen in the above link but that's just one example. Interesting that the hinge-to-body bolts are still available non-heritage.....PN 08116-8161G around $2 each (amayama).    Same thread but 16mm long.
    • Well, if that filter was impeding fluid flow, then it could have similar effects to faulty solenoids. The TCU will register a fault when it does something (ie, changes the state of a solenoid) and does not detect the required result. If there are other causes that can make the same lack of result, then they will be indistinguishable to the expected cause for which the TCU has a code.
    • Yellowjackets, red ones, blue ones (other than Splitfire) have all been demonstrated to be unreliable on turbo engines. That unreliability can be anything from outright failure (ie, 4 out of a set of 6 working out of the box) to just not being strong enough for the task, on a boosted engine. Not enough of us care about NA engines to know whether that unreliability is an issue for the undemanding needs of an NA RB20. I should think though that the DIS-008 should fit the 20. There's not really any reason for the head/coil mounting area to be any different on those 2 Neos. I wouldn't be buying Splitfires, or any other old tech coilpack, for a car in this day and age though. I would buy modern pencil coils and do what needs to be done to adapt them to the loom. That's relatively trivial these days, with numerous kits for fitting R35, or Audi, or Yaris/Corolla coils.
    • Keen to see how much work is needed to get an abandoned Skyline going. My R32 has been sitting idle for three years or so but finally got some time to get it going again. (Also lurking SAU and trying to hit 10 posts so I can start my own intro thread with pics)
    • Hi. Which coilpacks can i use in my engine? I looked at the Splitfire but the closest "match" i found was SP-DIS-008 but even that they do not show RB20DE NEO so iam not 100% sure. Or maybe different one which will 100% work? I saw many on ebay but they are some cheap "strange" ones. What about Yellow Jackets? Many thanks 🙂
