as title says, im stumped.
my tailight bulb has blown, ( only one so i have a half circle light lol) anyway i pulled off the boot liner to find no access to the bulbs. just metal.
now, im stumped, how do i get to them??
is it like the front indicators and u just lever them out with a screwdriver?
please anyone?
Mate you have to actually unscrew the light assembly and pop it out to get into the bulb.
You will need a 10mm socket from memory. There is 3 or 4 nuts. Undo them, pull the light out (with cover attached) and your away. :P
cheers mate, what a bitch of a job though, im assuming these 10mm bolts are insid ethe boot, and then it comes out form outside?
I did this not too long ago, its actually really really easy and takes next to no time at all.
Pretty sure it was just 4 nuts then the light assembly pops off. 10mm socket i think is right too. They are on the inside of the boot, behind the trim.
Edited by Scottydoo
    • The interesting part of tests like IM240 is they measure the exhaust output. But they never measure the gases going into the engine... Imagine doing the test in a densely populated city with higher CO2 levels around... Instant disadvantage...
    • I have two German Shepherds that like to bite things that are in places they shouldn't be. Plus the cars/batteries on chargers are inside a locked garage, inside that fully fenced and locked yard. If you can get the car out, you can have it, as I'll be having one hell of a laugh at your expense.
    • Looks like they changed the wording in the manual for the new model. I have a different model. Mine is CC1206. Not CC1206-XLI. Mine doesn't support lithium at all. I can't find the manual for my model online and they don't list the model on the Century website anymore either. In my manual it says what I quoted and that they recommend to not leave it on 🤷‍♂️ Sounds like you'd be fine with this one now.
    • Thanks for actually answering every single point! I noticed the date only after posting. And yes, looks like things have changed a little bit since then. FWIW, looks like Government Gazette No 253 has the current emissions test procedure. Sounds pretty reasonable altogether. One thing I learned from this is that it's possible to check whether a catalyst does any work by measuring the temperature. Catalyst outlet temp is at least 40°C higher than inlet temps if there is a reaction happening. I'd be curious to check this on mine but don't have a thermometer. Because purely going by smell it can't be doing much. Personally I'd be okay to pay for the test as long as it's within reason. My main concern would be to lose my rego because it definitely wouldn't pass the test in its current state. I'll see if I can do a bit more digging and see what's involved in doing this nowadays.   To be fair I don't think it's stopping many people from doing the modifications anyway. It just puts a barrier up to doing things right
    • Uhhh if anyone sees this - I bought a BRZ years ago, on my fulls soon so back on the market for the R34!
