  • Replies 115
Who cares what it sounds like? :P
Quote from the ESP guys from the last ESP dyno day thread:
"Hope everyone had as good a day as us and we are looking forward to the next day. We have made some enquiries and got some sponsors for the next day as far as prizes go"
Prizes - Hope there's one for 'most power on stock airbox' :cool: De-fault! de-fault!
Me either, I won't win anything - just read it and thought I'd paste it here :cool:
edit: nm read earlier post. I'll be out there about midday or so.. hope I don't miss anything too interesting!!!
Edited by sl33py
Congrats to everyone's efforts today. Thumbs up to Chris for organising and ESP for running it. I think there were a few people that walked away with a lot more knowledge and some asking themselves (or their other half) how much money they can spend before the next day....
I was very impressed and pleased to know that ESP's dyno read 1kw more than Jake's Performance. Consistency was near spot on!
Thanks for taking us for a quick lap to Ben, opened my eyes/ears to what a 1.5 way is like.
No probs, thanks to ESP for running the day, and going that extra mile, really appreciate it, and for everyone that showed up. Was great to see the R35's there, stunning cars and certainly put out some nice power. Already am thinking about spending some more money on my car lol :)
    • I believe when they added coolant to cool the turbo it negated the need for turbo timers as water continues to flow even when the engine is shut off I forget the actual terminology, I'll just say the coolant "percolates" through the turbo which stops the oil cooking itself to death  Well....that's how I see it, as all the plant at work that has coolant lines to the turbo can be shut down straight away, whereas the older plant with only oil feed to the turbo you need to idle it for a few minutes
    • What is the current snail?
    • Never an issue with boost control. No weird boost issues pre throttle at partial throttle like you're suggesting. It worked.   As for all the turbo damage claims, they all were started by aftermarket BOV companies. At least turbo timer companies had SOME truth about them, except people failed to realise that except for in extreme circumstances, that small amount of driving you do to park/ through pit lane etc, is enough to not have a need for a turbo timer.
    • I tell people all the time this stuff runs on a 2 MHz 8-bit MCU. The math is a bit arcane, they do a lot to get around their limited resolution and so on but it works great as-shipped. So if an 80 to 160 MHz modern 32-bit MCU can't make it work you've really screwed something up badly. Your average graphing calculator is faster these days, god forbid we start talking about what's hiding in vapes or some stupid internet-connected "smart appliance".  I suspect the lore about off-throttle surge damaging turbos must be very, very old if it was ever true. I still don't think off throttle surge is good for turbos because you're rapidly having air going in and out of the turbo on top of rapid loss in shaft speed which presumably does impart some kind of unusual load on the rotating assembly. As for the recirculating valve, I believe Nissan actually in a press slide deck of some kind explained for the RZ34 they found it improved response. Prior to that they kept the throttle cracked open instead which causes rev hang and because the throttle/engine is a substantial restriction a ton of the energy in the air stream is lost just to pumping past it. Recirculating helps reduce energy loss by bringing the intake side of the compressor up in pressure so it's not working as hard to pull air in. In DCT cars where they can slam gears I believe Porsche hangs the throttle wide open with no fuel injection to keep turbo RPMs as high as possible during the shift. As for running post-throttle boost source, I would be concerned that at partial throttle on boost you would have driveability issues. It would be constantly trying to run crazy amounts of boost before the throttle to compensate for the throttling effect. Maybe with a much more sophisticated boost control setup you could activate a solenoid that goes from a conventional 3-port setup to something that allows the wastegates to see full vacuum in that specific case?
    • Did you clean everything out? Take all intercooler piping off, empty the intercooler of oil, clean the exhaust out, etc? Intercoolers make great catch cans... Which makes them less useful for intercooling... But very worth cleaning out, along with all adjoining piping.
