Hi all
Got some stickers that I had made in recent trips overseas. Dont quite know why I had them all made up, most have gone on the toolbox/laptop etc haha
Note: this is not a trader sale!
Here they are:
The $10 ones
2 x white Mines (about 23x10cm)
2 x black Mines (about 23x10cm)
1 x white Greddy logo with dial around the G (15x7.5cm)
1 x chrome Greddy logo with dial around the G (15x7.5cm)
1 x Nismo logo (with red circle) (30x4cm)
1 x glossy grey TEIN logo that says 'technical innovation' with dampachi doll (18x5cm)
4 x GTR emblems with chrome GT and chrome outline (8x6cm)
1 x black running writing Nismo (13x4.5cm)
2 x chrome running writing Nismo (13x4.5cm)
1 x black HKS logo (12x5cm)
The $5 ones
1 x white Greddy logo with dial around the G (9x5cm)
1 x chrome Greddy logo with dial around the G (9x5cm)
1 x white standard Nismo logo (13x2cm)
1 x chrome standard Nismo logo, chrome O as well (8.5x1.5cm)
1 x chrome Trust logo (9x1.5cm)
1 x white Trust logo (9x1.5cm)
1 x chrome Trust logo (15x2cm)
1 x black Trust logo (15x2cm)
3 x Nismo logo with red circle (5x1cm)
2 x white Mine’s (9x4.5cm)
I have sold some of the others and hence they arent listed above even though they are in the pictures.
Note: the Mine's one with the black background is not for sale, the picture of the bottom one and ones like it are.
They have masking tape on the top of them, so all you need to do is peel the masking tape off (sticker comes off with it), then stick it wherever you want on the car, then pull the masking tape off slowly and hey presto!
In Sydney and can post easily. Can give a discount for bulk buys.
Thanks
https://www.sau.com.au/forums/topic/233456-vinyl-stickers-and-decals/
  • 4 weeks later...
  • 3 weeks later...
  • 3 weeks later...
  • 1 month later...
    • I have a VALCON if anyone wants it, I have no idea why you'd want to have VVT specifically broken out of the ECU as opposed to running it off the FCON/whatever standalone you have.
    • Hi Yes we're a bit optimistic we might get something out of sealing up the two pipes of the external wastegate and reactivating the stock one. I believe the orginal stock wastegate was tack welded shut. It doesn't budge and visually looks closed and sealed. The car has noticeably more lag so it could be at least part of the problem, maybe all. It's definately one of the key changes made since last tune. And it's one that's more difficult to fully understand and measure, not like for instance timing or cylinder compression.  Thanks for that feedback, we'll let you know how this progresses. Fingers crossed.   Regards Rob
    • Transplanting the vvt from a 25neo into an rb26?
    • Well, I was going to say, "Is the wastegate set up so that it is not leaking?" That's actually a different thing to what you're asking about. In theory, if you have allowed the two halves of the manifold to commmunicate (more than the stock manifold does - which is at least a little bit) then the negative effect should be apparent in delayed spool, not in outrigth power. OK, maybe just maybe, a badly set up twin scroll wastegate "crosstalk" might kill the top end, although it's hard to see how. What is happening with the original wastegate in the turbo? is it sealed off properly. If it's left flapping in the breeze, it will f**k everything up. If it is still there, and can be returned to service, I'd be capping off the external (presuming the two halves can and will be isolated from each other after doing so) and have a go with just the stock wastegate. I have an internal wastegate in my highflowed rear housing. The bigger opening and flapper should be fine to >250 rwkW. So there's not exactly a pressing reason to have the external. Done right, an external will give better results. Done wrong, it might just be possible to have worse results. Report back!
