Item: R32 3" Fujitsubo Legalis R Evolution catback exhaust
Age: Age unknown, as it was on the car when i had it imported, was assume around 1-2 years old
Condition: Excellent condition, small scratches on the underside of the tip from speed humps, and also on the mid muffler, these are not visible when mounted on the car.
Price: $350 ono
To Fit: (What car) R32 gts-t and also i think gtr (correct me if im wrong)
Location: Melbourne (Glen Waverley 3150) pick up only!!!
Contact: 0431 222 796 (Andrew)
Comments: This exhaust is in excellent condition and is the perfect exhaust for those who dont want anything too loud on idle and off boost driving. Nice quiet note when driving normally, but as soon as you put the foot down it sounds amazing, screams so nice at high rpm!!! Have had many good comments about the exhaust note!!
Also have the original documents from the purchase of the exhaust in japan, they were in my glovebox when the car was imported!!
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
