G'Day,
I want to remove the ABS off my GTR. I assume I use a GTS-T master and run some new lines, but what happens to the attesa system, as it uses the ABS sensors. Will unplugging the abs unit interfere with the 4wd?
https://www.sau.com.au/forums/topic/233476-r32-gtr-abs-removal/
What makes you say that?
The ATTESSA unit has a number of inputs/outputs that also affect the ABS operation. So if you deactivate the ATTESSA system you render the ABS useless as well as the 4WD system. But this is not the same as saying you can/can't remove the ABS without upsetting the ATTESSA system.
Secondly, why would you want to revert to a GTS-T master cylinder? It is too small in bore size.
My mistake, looked through the manual and it seems that losing any of the abs actuators / motor relay / or circuit will just disable the abs not 4wd, as you said. I was thinking along the lines of the hicas where one thing kills the lot in that module.
A question for you as well,
What is the bore size of gtst and gtr master cylinders? I have 32'R brakes and I am unsure of the master cylinder matching, brakes are horrendous though..
I thought the GTST and GTR Caliper's had the same size pistons, therefore, I thought I would use a GTST non ABS master cylinder with the three outlets. Is this not the way to go? What is the way to go?
Has anyone disconnected their ABS unit and done a launch to see if all 4 spin? I would but my engine is broken.
from http://nissans15.com/brakes.htm
Model Type Master Cylinder Diameter
S15 Spec R BM50 25.4mm
300zx turbo BM50/57 25.4 and 26.9mm used
R32 GT-T M-spec BM50 25.4mm
R33 GTST BM44 23.8mm
R32 GTR non Brembo BM50 25.4mm
R34 GTT ? ?
R32/33/34 Brembo* BM57 26.9mm
* GTR N1 Skylines apparently used the BM50 MC.
also this might be interesting, someone else chasing a 3-port 1" master cylinder.. http://www.sillbeer.com/2007/04/brake-mast...er-upgrade.html
But looking here http://www.ipixel.com.au/temp/bnr32n1bmc/bmc-46010-range.gif there is whole slew of different models used.
Looking at the bmc from the drivers side the model is towards the booster right next to where it says nissan. Last digits of the part number are stamped on the very end of the unit, for example mine are 05u20, ie 1".
Edited by heller44
R34 GTT ? ?
So the non M spec R32 GTS-T has what size master cylinder?
  • 5 years later...
    • Nope, still smaller rear, put on the 4inch exhaust and picked up power everywhere, ended up just shy of 800rwhp.   Didn't seem to be hitting any walls either, so perhaps could have pushed for more but all maybes and the fish that got away etc etc.
    • Races cars don't care for VIN either...
    • This could be sold and shipped to the US for many gold pieces. RMS has no say in that. Ask various Western Sydney inhabitants how it works.
    • Ha ha ha, mine loves to spend, all on the dogs (they're our kids, and her spending would likely rival that of some people raising children!) the only benefit is, her spending is tax deductible as she runs a business in the dog industry 😛 The above all means she can spend race car budget quicker than I can. 😛 That and a lot of the things I want are very expensive, and I can be a bit "you want how much for that?!" And at other times overly impulsive. Or I start the w days of research, get to day 1.5 and get really annoyed that no one will advertise actual specifics and it's just marketting BS and I go "well, now I don't want anything to do with that now!" Also I hate paying lots of money for something I can make from $50 in materials. Then I get the shits halfway through making things and wonder why others who just buy parts have more fun... 😛
    • Their 240Z with the RB26 would be a real nice thing to have in a garage to come out for an occasional weekend cruise It's such a cool thing in so many ways Sadly, we have a blue 240Z shell that I walk past every day, just sitting outside a shed at work, it has been slowly disintegrating and falling apart into the ground for the last few years, the owner cannot be found, and I am unable to "claim it" I've been told by work and the RMS, the rust in the body is excessive though, and it has had most of the salvageable stuff, like panels, trim and switch gear stripped off it over the last year or two, work keeps threatening to put it in one of our metal scrap bins, I wish they did though, as it makes Mark sad walking past it
