sorry guys, real quick q...
this is my tune:
my hks adjustable actuator only goes down to 19psi... we tried all methods, its the lowest it will go... im running a stock dump/front... some ppl say its overboosting coz of that, some say it wont matter im sick of hearing bs, all i would love to know is if running 19psi n the occasional limiter bash at winton drifts next sat will be safe?
i ran this exact setup for a year n a half n a couple of weeks ago cracked first n 6th piston (looks like an over time thing)... i would rather not have a repeat of this if boost was the cause.
thankyou in advance!
emz
https://www.sau.com.au/forums/topic/233501-rb25det-hks2535-19psi-safe/
I used to have the same setup on my R33 and to be safe I would turn the boost down on track days ad also run a quality octane boost.
Does it hold 19psi to redline? if it falls off towards the end of the rev range then it may not be to bad.
Is the motor built for 19psi?
why on earth would you run a larger turbo with std front and dump pipe?
no wonder you cant lower the boost, its trapped in the housing!!
change the front pipe/dump pipe even if you dont want more boost
We'll all heard this so many times from you...the solution to your overboosting is your stock dump...it has been told to you several times...whether or not it holds to redline is beside the point at this moment...
Now...as for 19psi at winton...its probably not the best idea...especially if your high boost is a result of a restriction...people usually wind boost down a few psi for safety at the track...couple of laps at WOT will have EGTs through the roof as well...and then risk of detonation will be another issue...its a bad idea if you ask me...and is an accident waiting to happen...
i had 2 different 3" dump/fronts
both different brands (i wont mention on the forums) one was the split n other the bellmouth design and both warped.. one from the turbo/dump n the other from the front/cat.
f**k buying cheap 300 shit.
does that answer ur question? sorry i dont mean to be rude but as a student i cant just go off n buy expensive shit, especially not a week before winton lol.
im just really after a quick fix for next weekend, then might sell my recaro seats n buy a proper jap dump/front.
cheers guys
first one was kinda my fault..
every1 warned me that the gaskets that came with the kit WERE SHITHOUSE... but some people said they will be fine. so instead of going to nissan n getting some, i just used the ones that came from the kit... my fault coz i got lazy.
2 weeks later, gasket failed, exhaust leak for a day or 2... ordered gaskets off nissan, pulled the dump off n realised the metal warped, no chance it was going back on so i returned it.
different brand kit, used the nissan gaskets... this time warped from the front/cat... looks like it was caused by shitty welding.
till this day i havnt heard anything bad about the jjr items... can they be trusted?
Edited by DjeMz
Well, I bought the Xforce bellmouth in mild steel and its been a treat for the almost 2 years i've had it.
Maybe get one fabbed up for you at a reputable exhaust shop. Shouldn't cost you a great deal more and at least you know the quality will be good. But yes being a student and funds and stuff etc etc....
That boost and those a/f ratios at the top end; you're asking for trouble.
RB25's are known to have weak ring-lands and the boost and leanness of the tune will generate more heat which can cause issues. I personally wouldn't risk it.
I consider anything over 12:1 a/f ratios, on a std RB25 and doing track days a BIG risk.
I ran 18psi, with 11.5:1 a/f ratios and still managed to crack a ring-land, pics below. All other components were in top nick, even the piston top, bore, etc of the cracked piston where completely undamaged.
Don't worry about split pipes or stainless; just get a custom made bell-mouth mild steel dump from a good exhaust shop. Should not cast you too much.
^^^ thats exactly wat happened to my old 25...
"I consider anything over 12:1 a/f ratios, on a std RB25 and doing track days a BIG risk."
drifting at winton isn't as bad as circuit, we do a few corners n line up for 5-10 mins then go out again...
i need something asap before winton, im not going to risk my new motor over it..
Edited by DjeMz
If your short of the $$, maybe someone close by to you would be willing to let you borrow one for a short time. Otherwise, maybe you'd want to check the for sale threads, there's cheap second hand goodies in there.
Its not the afr's that kill the engine ................... it doesn't matter if you have a "richer tune" if it detonate's it will do more damage with rich tune than a lean tune.
Maybe your solution is to fit a better dump pipe then check / retune or not fit the dump and get a safer tune ?
I am not suggesting your tuner did not tune it safe but if you don't want to blow another cheap shit rb25 then get it detuned.
That's right, but a lean tune creates more heat, more boost creates more heat, this setup has both. What can promote detonation? You guessed it..................HEAT.
May be alright on the dyno, but on the track and under the car's own load, detonation may occur. I would consider that top end tune unsafe for a "built engine" let alone a std one. Holding 19psi to red-line ain't doing it any favours too.
Just a second thought though :(
-If the dump is restrictive doesn't that slow down the exhaust gasses, so shouldn't the turbo be creating less boost than expected or at least dropping off dramatically?
- Just thinking whether the car may have another issue :)
Personally i would give this event a miss, knowing my car is not running properly. Can you afford possibly blowing another rb25? Is this event that important to risk all?
Just saw you sig, so obviously this Winton day is important to you.
Having my car at DECA, on my 30th B'day was important to me too, but that didn't happen; knowing now that my car is 100% ready and working perfectly is more important. There will be other events and other B'days, hell i was glad i didn't have it, as i would have had to drive it back the next morning :(
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
