^^ i totally agree with u dude. i really need to piss off this emanage, i watched him tune it, theres f**k all room for fine adjustments with the emanage... could also be the fact that i have a central 20 ecu as well, might be conflicting somewhere??? ahhh if only pfc were cheaper...
Your call but I reckon a little more turbo and a little less boost , jeez those 2535's aren't real big on the hot side and the restriction generally leads to a thermal thrashing .
Pro S and IW GT3071R's cost a bit but you get much less restriction from them on the hot side and a more modern compressor wheel as well .
Again IMO the whole dump flange system from the std Hitachi footprint is not the best one to go beat the world with .
I understand that bolt on turbo solutions have to keep it but it has its limitations .
A .
Easy answer is throw on a Nissan RB25 wastegate actuator and get the boost down under control. Boost alone wont kill the engine, temperature alone wont. Revs alone wont and coolant and oil temps wont kill an engine alone.
As others have pointed out, you are borderline on boost, and its the worse sort of boost in that the engine isnt working effeicently with effecient exhaust of combusted gases. Its choking on the gases. So combined with the bog revs and high coolant / oil temps you see drifting....like i said i would be getting the boost back down to 13psi. Then get the breathing on the engine sorted.
hey seriously i would just dump some extra fuel up top to be safe, the tune is good but if you cracked 6th it was detonating and i would reckon that the tune was the cause.
Knock 3 degrees off the map and add some fuel up near the limiter (depending on how you drive)
im happy to have a look at it one night if you want.
I have NA sr20's with td06's runing 19psi with emanage no problems. The emanage is a great unit if the user knows what they are doing.
That boost and those a/f ratios at the top end; you're asking for trouble.
RB25's are known to have weak ring-lands and the boost and leanness of the tune will generate more heat which can cause issues. I personally wouldn't risk it.
I consider anything over 12:1 a/f ratios, on a std RB25 and doing track days a BIG risk.
I ran 18psi, with 11.5:1 a/f ratios and still managed to crack a ring-land, pics below. All other components were in top nick, even the piston top, bore, etc of the cracked piston where completely undamaged.
Don't worry about split pipes or stainless; just get a custom made bell-mouth mild steel dump from a good exhaust shop. Should not cast you too much.
that is the result of det most likely nothing to do with the a/f. I have a few tough mid 300rwkw rb's running leaner than 12.2:1
that said in DJEMS position i would fatten it up as i know nothing of the timing map.
Wouldn't det have shown on top of the pistons?
ie: pitting or rough'ish surface.
Apart from the cracks between the ring-lands, everything else was in pristine condition.
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
