^^ i totally agree with u dude. i really need to piss off this emanage, i watched him tune it, theres f**k all room for fine adjustments with the emanage... could also be the fact that i have a central 20 ecu as well, might be conflicting somewhere??? ahhh if only pfc were cheaper...
Your call but I reckon a little more turbo and a little less boost , jeez those 2535's aren't real big on the hot side and the restriction generally leads to a thermal thrashing .
Pro S and IW GT3071R's cost a bit but you get much less restriction from them on the hot side and a more modern compressor wheel as well .
Again IMO the whole dump flange system from the std Hitachi footprint is not the best one to go beat the world with .
I understand that bolt on turbo solutions have to keep it but it has its limitations .
A .
Easy answer is throw on a Nissan RB25 wastegate actuator and get the boost down under control. Boost alone wont kill the engine, temperature alone wont. Revs alone wont and coolant and oil temps wont kill an engine alone.
As others have pointed out, you are borderline on boost, and its the worse sort of boost in that the engine isnt working effeicently with effecient exhaust of combusted gases. Its choking on the gases. So combined with the bog revs and high coolant / oil temps you see drifting....like i said i would be getting the boost back down to 13psi. Then get the breathing on the engine sorted.
hey seriously i would just dump some extra fuel up top to be safe, the tune is good but if you cracked 6th it was detonating and i would reckon that the tune was the cause.
Knock 3 degrees off the map and add some fuel up near the limiter (depending on how you drive)
im happy to have a look at it one night if you want.
I have NA sr20's with td06's runing 19psi with emanage no problems. The emanage is a great unit if the user knows what they are doing.
That boost and those a/f ratios at the top end; you're asking for trouble.
RB25's are known to have weak ring-lands and the boost and leanness of the tune will generate more heat which can cause issues. I personally wouldn't risk it.
I consider anything over 12:1 a/f ratios, on a std RB25 and doing track days a BIG risk.
I ran 18psi, with 11.5:1 a/f ratios and still managed to crack a ring-land, pics below. All other components were in top nick, even the piston top, bore, etc of the cracked piston where completely undamaged.
Don't worry about split pipes or stainless; just get a custom made bell-mouth mild steel dump from a good exhaust shop. Should not cast you too much.
that is the result of det most likely nothing to do with the a/f. I have a few tough mid 300rwkw rb's running leaner than 12.2:1
that said in DJEMS position i would fatten it up as i know nothing of the timing map.
Wouldn't det have shown on top of the pistons?
ie: pitting or rough'ish surface.
Apart from the cracks between the ring-lands, everything else was in pristine condition.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
