I found this on another forum and thought it was good, so im sharing.
Here's a guide on how to carbon overlay parts of your car.
You will need the following parts -
Carbon cloth (twil looks best)
resin
acetone (if u want to clean your brushes - i use cheap ones and bin them)
plenty of latex gloves
mixing pots
measuring jug
syringe (for measuring hardner)
masking tape
Sharp scissors
Some stirrers - I use wooded spatulars
emery cloth
wet n dry 400grit to 1200 grit
polish
1) measure up your carbon cloth for the piece to be covered. Then using the masking tape tape up both sides where you intend to cut the cloth to prevent pulling the weave then cut through the middle of the tape -
2) Prep your piece to be overlayed - it should be black, if its not spray it up first so a colour doesnt show through the weave. It also needs a rub down with emery cloth.
3) brush a thin layer of resin mixed with 1% harder over the part to be overlayed then press the carbon cloth gently into place and tape up to the rear of the part to pull it into shape. You may need to change your gloves often so you dont pull the weave. Leave to dry for approx 45mins
4) Start building up thing layers of resin, you will need approx 5 layers to prevent breaking through to the cloth when sanding down. Each additional layer should be added after around 7 mins when the previous layer turns to a jelly consistency. You will now need to leave it for 1 week to fully cure -
5) you will now need to trim the excess cloth off - best tool I found was a dremmel -
BEFORE:
AFTER TRIMMING:
6) Start sanding down. work your way from 400 grit up to 1200 grit wet and dry then finish with a good quality polish for a really nice shine -
https://www.sau.com.au/forums/topic/233506-carbon-overlying/
Yeah thanks guys.
Im not sure on cost for all the materials. You should be able to get the carbon cloth from most custom fibreglasses.
I think it would be Harder then it looks but i think it can be done but u need to take ur time in doing it.
Adam
how would you go about doing dry carbon finish :S ?
Dry carbon uses a completely different production method and shouldn't be confused with wet-lay up.
I will assume you mean a raw finish which is most commonly associated with 'dry carbon' which can be achieved by just leaving the carbon with the resin and not adding a clear coat.
yeh just a matte finish without the gloss
  • 3 weeks later...
um not sure how mine is gonna turn out, my cf stitching is comptletely drifferent compared 2 ur's.
im practicing on sum pieces of wood 2morro. lol
how did u get the material 2 stick in2 the grooves? im guessing glue maybe.
my stitch's are just like lil squares side by side. ie. ooooooooooo
ooooooooooo
ooooooooooo.
i'll post a pic up 2morro. that'll b easier. lol
Sounds like you have Plain Weave Carbon Fibre. The stitch is woven in a checker pattern.
The carbon used in the pictures is 3k 2x2 Twill weave (most common carbon fibre found)
PSI Parts
how go is the carbon fiber and risen in hight heat condition
define high heat, then an answer can be provided
look into auto-claving - used with vacuum mnolds and pre-preg carbon fibre - AKA how a ferrari is built. you cant do that at home, but it will tell you the curing temps.
also - you can powdercoat fibreglass if its done correctly - so it can handle 230 deg C atleast
i was thinking of carbon fiber over laying my timing cover and igniion cover.
so it should work? :)
  • 1 month later...
Nah bugger autobarn,,,any good boat shop sells it.
No carbon fibre but heaps of fibreglass stuff.
I found this place at Warwick farm,,,I went out to have a fag at lone star and they were next door and they have lots of shops.
http://www.biasboating.com.au
Neil.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
