I found this on another forum and thought it was good, so im sharing.
Here's a guide on how to carbon overlay parts of your car.
You will need the following parts -
Carbon cloth (twil looks best)
resin
acetone (if u want to clean your brushes - i use cheap ones and bin them)
plenty of latex gloves
mixing pots
measuring jug
syringe (for measuring hardner)
masking tape
Sharp scissors
Some stirrers - I use wooded spatulars
emery cloth
wet n dry 400grit to 1200 grit
polish
1) measure up your carbon cloth for the piece to be covered. Then using the masking tape tape up both sides where you intend to cut the cloth to prevent pulling the weave then cut through the middle of the tape -
2) Prep your piece to be overlayed - it should be black, if its not spray it up first so a colour doesnt show through the weave. It also needs a rub down with emery cloth.
3) brush a thin layer of resin mixed with 1% harder over the part to be overlayed then press the carbon cloth gently into place and tape up to the rear of the part to pull it into shape. You may need to change your gloves often so you dont pull the weave. Leave to dry for approx 45mins
4) Start building up thing layers of resin, you will need approx 5 layers to prevent breaking through to the cloth when sanding down. Each additional layer should be added after around 7 mins when the previous layer turns to a jelly consistency. You will now need to leave it for 1 week to fully cure -
5) you will now need to trim the excess cloth off - best tool I found was a dremmel -
BEFORE:
AFTER TRIMMING:
6) Start sanding down. work your way from 400 grit up to 1200 grit wet and dry then finish with a good quality polish for a really nice shine -
https://www.sau.com.au/forums/topic/233506-carbon-overlying/
Yeah thanks guys.
Im not sure on cost for all the materials. You should be able to get the carbon cloth from most custom fibreglasses.
I think it would be Harder then it looks but i think it can be done but u need to take ur time in doing it.
Adam
how would you go about doing dry carbon finish :S ?
Dry carbon uses a completely different production method and shouldn't be confused with wet-lay up.
I will assume you mean a raw finish which is most commonly associated with 'dry carbon' which can be achieved by just leaving the carbon with the resin and not adding a clear coat.
yeh just a matte finish without the gloss
  • 3 weeks later...
um not sure how mine is gonna turn out, my cf stitching is comptletely drifferent compared 2 ur's.
im practicing on sum pieces of wood 2morro. lol
how did u get the material 2 stick in2 the grooves? im guessing glue maybe.
my stitch's are just like lil squares side by side. ie. ooooooooooo
ooooooooooo
ooooooooooo.
i'll post a pic up 2morro. that'll b easier. lol
Sounds like you have Plain Weave Carbon Fibre. The stitch is woven in a checker pattern.
The carbon used in the pictures is 3k 2x2 Twill weave (most common carbon fibre found)
PSI Parts
how go is the carbon fiber and risen in hight heat condition
define high heat, then an answer can be provided
look into auto-claving - used with vacuum mnolds and pre-preg carbon fibre - AKA how a ferrari is built. you cant do that at home, but it will tell you the curing temps.
also - you can powdercoat fibreglass if its done correctly - so it can handle 230 deg C atleast
i was thinking of carbon fiber over laying my timing cover and igniion cover.
so it should work? :)
  • 1 month later...
Nah bugger autobarn,,,any good boat shop sells it.
No carbon fibre but heaps of fibreglass stuff.
I found this place at Warwick farm,,,I went out to have a fag at lone star and they were next door and they have lots of shops.
http://www.biasboating.com.au
Neil.
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
    • FYP. Sadly. Even bolt cutters wouldn't take 2 sec. But in the days of 18v angle grinders, nothing is safe.
    • One piece driveshaft I would recommend a dual CV setup otherwise stick to OEM. I have heard most one piece driveshafts cause excess vibration otherwise. The transmission grind I'm quite familiar with. You can try shockproof gear oil, otherwise you need a new transmission. The shifter is extremely simple on these cars. If you want pull apart the assembly and replace the plastic bushing but I doubt that fixes anything. The tail light issue is very common, unfortunately new tail lights are long discontinued. The trunk antenna going up always is because your radio doesn't have a true power antenna control, just remote amp power signal. There is a blank switch plate that you can pop out and install a switch for this or alternatively source a head unit that has proper antenna control. Throttle body sticking you have to disambiguate by disconnecting the cable and seeing if the linkages are the problem or something else. There is a procedure to adjust them, refreshing them is also somewhat involved if that's the issue. I have dealt with many of these issues. Old cars really are fractals of problems. The more you fix the more you discover there is to fix.
    • Welp, you've got a long list of experiences right there. I'd say you're on the right path.
    • That's correct, suits my requirements a bit better. Sure there are also numpties there, however it's generally a different vibe and more my kind of vibe.
