Item: 2x R34 GT-R N1 Turbo's (includes wastegates) and manifold.
Website: n/a
Item Condition: Excellent condition
Reason for Selling: No longer required as I've upgraded to a large single turbo.
Price and Payment Conditions: $1,800 for the turbo's, wastegates & manifold (not seperating any of this).
Extra Info: Excellent upgrade for R32, R33 & R34 GT-R Skyline's running standard turbo's. No shaft play and in excellent condition. Only done approximately 20,000k's.
Pictures: Will upload some soon.
Contact Details: PM ME or reply in here!!!!
https://www.sau.com.au/forums/topic/233524-r34-gt-r-n1-turbo-package/
Website: n/a
Could you please email me images I would definatly be interested in htese. Thanks
Dave
[email protected]
I've replied to all the PM's....
The turbo's come off this weekend so I'll be taking pic's then.
As stated in the PM's.... They've only done approximately 20,000k's.
about 10,000k's by the previous owner and about 6,000 by me or there abouts.
received offers but i'm still taking offers....
pic's will be uploaded onto this thread on the wknd once the turbo's are taken off.
My friend,
as a suggestion, once you have those turbo's off the car, please post the serial number that's on them. That will let everybody know what exact specs they are as there were a few in the R34 series.
Beauty!!!
My friend,
Beauty!!!
yeah i second that... keen to see images and id of the turbos first.. thanks
My friend,
Beauty!!!
FYI turbos are AA-403's, latest gen r34 n1's :(
Did you get these of SHANEF
Or is his comments above, just a little coincident.
That little shit...still hasn't paid for the set he got of me...along with numerous other parts...a bit over $6000 worth.
He doesn't like to return calls etc.....his daring me to have him charge with thief.
Phil.
0409573124
Edited by GTR STI
  • 1 month later...
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
