hey guys......... ive gotta question..... Not too long ago when i got work done on engine, i asked the mechanic to change the clutch as i purchased the car off them with a soft worn clutch.....
He said ye no worries, i get the car back and i felt the clutch and was like wtf is this. Was so soft man wasnt normal..... I go to him dude thats softer than before,,, his reply was "just drive it, the car needs to get used to it...... 1 month later and it is still real soft.
its not crunching.... it takes fast gear changes fine, but its soo soft.. I dont mean in a complete dumb way as i know clutches shouldnt be real soft.... but is that normal i dont wanna keep going and driving etc then one day i have a car that wont move.
Any info would be good. Cheers
antoni
https://www.sau.com.au/forums/topic/233530-soft-clutch-yet-new-clutch-plate/
Its not the clutch disc that determines how heavy the pedal is, its the pressure plate and even more specifically the diaphragm spring (they usually come as one unit). If he just changed the clutch plate then the weight of the pedal wont change at all. What you need is an upgraded pressure plate with a greater clamping force.
Well its basically another clutch swap mate....so whatever he charged you for that + the cost of a new clutch kit. Your better off buying a kit as it will come with everything you need just make sure you get one with a high clamping force if you like the pedal to be stiff.
so would it be wise just to take it to a workshop and see if they can do me a deal.... cos my mate has a standard clutch in his r32 and its way harder than mine, so how much u rekon i cud pick up a standard clutch before i go get ripped off?
The "softness" of the clutch relates to the leverage factor built into the "fingers" between the thrust bearing and the diaphragm spring. It's quite possible to have a heavy duty clutch (high pressure rating) that is light to use.
If you only asked him to change "the clutch", then he probably only changed the driven plate. What did he charge you for?
he done it for free, as he was the dealer i got it from. But ye so would i still need a replacement to make it harder, i heard you can harden it yourself just tighten something, id prefer to get a professional to do it. How much would that cost. Soz everyone when it comes to clutch im clueless, anything else im cool with it haha.
    • Just checking, when we are talking about high temp fluid, are we all referring to DOT 5.1? I haven't had any issues with changing it every 2-3 years.
    • Yeah that is still true AFAIK.....good brake fluid should be changed annually because it absorbs water faster which is more often than most mechanics would do it. There are cheap tools that check water% in brake fluid if you all scientific about it. I for sure would (do) run good brake fluid in anything that even casually saw the track like Murray said; avoiding the risk of "exciting" fade is worth it
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
