i'm currently wrecking my r33 due to an accident last week.
i have:
door with mirrors complete $150 each
lh front guard $50
complete interior $250
rb25det complete with loom,ecu,cooler,all botl ons etc STANDARD $1600
r33 diff complete $300
front and rear brakes,with disks $250
standard r33 16'' wheels and tyres $250
cat back 3'' exhaust including hi flow cat $300
gearbox and conversion SOLD
roof and 1/4 cuts available
bilstein rear shocks $50
many more parts available.
r32 gts-t
good clean bonnet $100
as new headlights and indicators $200 the lot
guards $50 each
diff complete $250
3 inch exhaust, turbo back with hi flow cat $300
rb20det full head with turbo and bolt ons, ecu loom etc $650
Please phone 0413 332 524 after 4:30 week days or anytime weekends.
https://www.sau.com.au/forums/topic/233544-vicwrecking-r32-and-r33-gts-ts/
What year is it?
Complete interior, does it include seats, door trims? Got boot trim?
You got side mount intercooler air guides?
And where in VIC are you at?
If the interior is series 2, I'm definitely interested
Cheers
Grant
brakes SOLD pending payment
car is a 94 model, burgundy in colour. s1 im guessing as it has the low boot spoiler and no pods,skirts etc
interior is very clean with the exception of a little wear/tear on the drivers seat from getting in and out. for 250 you can have the seats, door trims (no switches) centre console, carpet parcel shelf and whatever fiddly bits u need.
yes i have complete boot carpets, panels and beaver cover.
I know i have no feed back, obviously this gives doubt for interestate buyers. im a member of calaisturbo.com.au using this same user name so feel free to check my trader rating on there if you have any trust issues. land line number etc will be given to interstate enquires if need be.
this is a regretful salvage due to an accident friday morning last week.
also rear taillights $150 the pair complete
clear centre garnish $50
rear bumper $100
front and rear steering and any suspension arms etc from $20-100
if some1 wants the sunroof $200, and ill cut the roof from the pillars if need be
Hey mate,
Thanks for calling me earlier! I am defintely taking some bits from the boot including the plastic trim around the latch if it is in good condition i.e. no cracks etc. I have been chasing that for months now. :P
Cheers and see ya real soon!
interested in the front cut, upper / lower arms, and strut towers mainly (if str8) not worried about rad support etc as im swapping the towers into s s-series.
is it damaged in the front badly?
r32 reverse lights/lense are sold already sorry
33 has rh front skirt damage and has pushed the tower back around 15mm. wheel was also back so unsure of suspension condition
engine is spot on, and for the cash and considering the car has never been boosted up etc it s a good buy.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
