definately does make a difference, power is travelling through more parts of the drivetrain hense loss of power there.. power delivery
your theory is correct....in theory.
in the real world this is how it works...500kw transfered through a component will produce a certain ammount of heat and this is the power loss. 350kw transfered through the same component will produce less heat and therefore less losses. So transfering 500kw through two diffs one seeing 150kw and the other 350kw will disperse heat and losses in the same way as 500kw through one item.
Forget the theory's though....ive done it on several dyno's in different cities and its a very minimal difference between 2WD and 4WD....end of story!
Edited by DiRTgarage
You are wrong....we have proved this theory on more than one occasion in front of hundreds of people at Autosalon. The difference in a 500AWKW car.....2KW.
Ok, I know we're off topic quite a bit, but it must be said... I don't like saying anything on forums unless I know I'm 100% correct. And, no matter how much I argue the point, I'm only ever going to get flamed by people here that don't know what they're talking about. It's just the anonymous nature of forums unfortunately.
I have seen on many occasions, particularly GTR Skylines, especially R32's, where I have seen 600HP AWD cars make an extra 50HP in RWD mode.
As an example, a particular car down south, makes 990 AWHP and when run on the same dyno, because the ramp-up rate is so much more aggressive in RWD mode, it makes around 1200HP before it wants to turn the rear tyres.
Talk to any tuner in Australia worth their salt, and they will all tell you the same thing.
the dyno they were refering to earlier was a Mainline at Autosalon...this phenomenon of higher readings in RWD does not work on a dynolog dyno...fullstop end of story. Dyno dynamics dyno's yes will read higher if the proper ramp rate is not used (a trick ive employed to win Dyno Dynamics dyno comps in the past by torque splitting minimal front drive)
Ill now shut up as ive got no idea what im on about as im extreemely inexperienced and know nothing.
Well....
:P LOL
of course it does! How about you get away from your keyboard for a moment, and actually pull two dyno runs, one a 2WD dyno and one on a 4WD and post up the differences in power delivery and torque curve and try to tell me otherwise...
:down:
Seeing as though Paul posted above... what you do you have now?
And its not the first time this been the case either, enough threads on it now to backup the fact there is MINIMAL difference.
    • Just checked in first post and you should be able to bring it home November this year, right? I'm amazed you made it through four years of this. As hard as it feels now the rest will go by in a breeze in hindsight, I'm sure.
    • Realized I haven't been back here in a while. Still here, still alive, still waiting for the car.  I went back again the only time last year from Oct-Nov for R's Meeting and drove it around some more, including a few laps on Fuji Speedway(in the wet, sadly). The car still feels good, but have a couple small things to address. I've been getting more parts but have slowed down still, and most of the bigger purchases are now out of the way. I find myself getting impatient more and more when it comes to getting started on this project; it's quite hard for me not being able to really dive in and start making this car my own because it's halfway across the world. At times it doesn't even really feel like I own one of these. Haven't really been motivated or had the desire to document the last trip on here or social media for, well, reasons... but here's some pics...it's also still alive and well as you can see: I've narrowed down to the last large part purchases(anything over $2k) before the engine build to be: 1) Ohlins Road & Tracks 2) ATS Twin Carbon clutch 3) Endless BBK with some custom options and 4) Kansai Service carbon driveshaft I don't think the budget exists for all of these this year, but I'll try for one or two items I think. Though, every time I look at my spreadsheet I sigh, shake my head, and get depressed just that little bit more.  'til later.
    • It's a stunning location!  I've been to NZ twice but haven't made it to the North Island yet.  Definitely on the cards but the South Island is hard to tear yourself away from too... Looking forward to see what you can wring out of it once you can get it to hold together!  Be awesome to get a low 11 or even sneaking into the high 10's pass out of it.  That's a bloody quick car that most people will never experience in their life.  Enjoy!
    • Nominally yes but I’m not really at that stage yet. Outsourcing to Japan is also a relatively good deal at the moment because their currency has devalued much more against the USD.  You would assume this but a lot has changed from the pandemic. Mechanics are in short supply and demand for fixing old cars has gone up from the cost of new cars. 250-300 USD/hr is not an unusual shop labor rate in California and you’re paying that regardless of whether the guy is competent or not. Coworkers have been quoted 3000 USD for a water pump and thermostat at a dealer on an N54. Oil changes went from ~75 USD to 150 on fairly normal cars like Civics. The cost of the oil and filter hasn’t even kept up with inflation.
    • The downside to that is that the cost of everything, particularly labour, is significantly higher here than it is over there in the Disunited States of Slavery. You can hire 3 tradesmen over there for just the Ranger Raptor allowance of a single 3rd year apprentice over here.
