I have a series 2 with zenon headlights and about a week ago my headlight changed from a bright clear light to a pink dull colour. 2 days ago it started to flicker and then it blew. So i pulled out the globe and it was broken. I went into autobarn this afternoon and priced one. because it was a philips brand globe the dude rang philips direct. I was thinking it was going to be around 150 each. He said ud better take a seat and he told me what they r worth. I nearly fell over. $404 each or he can do 2 for $660. Bloody bullshit.
Anyone know where i can get one a bit cheaper?
Any help would be good
Thanks
https://www.sau.com.au/forums/topic/233582-blown-headlight-globe/
you need D2R globes. get between 4200k and 6000k,any higher is a waste of time. ebay,or your local aftermarket parts shop will be able to hook you up.
I paid $150 for a pair of 6000k globes a couple of months ago through autojoy in parramatta when one of my std lights died.
Justin...
Justin...
found them on ebay. thanks. What do the 4200k and 6000k figures mean. Whats brighter, whats better? Ebay has 4200k from the states for 119 us plus postage. or 5000k ones. which one should i get?
did you want the short or long answer ?
Lighting colour is measured in Degrees Kelvin
daylight is around 5500-6500 degrees kelvin
a normal incandescent globe is around 2800-3300 kelvin
and a candle is around 1700k
the colour temperature (degrees kelvin) doesnt really tell you how bright the lamp assembly is
from memory the bluer lamps (higher K number) are slightly more efficient, but the difference will not be noticable on the road.
the bluer lamps also dont seem to throw a beam as far in the wet, and the bluer lamps also change your colour perception
i would reccomend something in the 4200-6000k range - it will be bluer than the normal incandescent light, but no so blue that everything looks weird
Edited by Echo63
a mate of mine from work recently got a plug and play HID kit off ebay- cost him something like $110 delivered- cant say how well they work as we have not instlled em yet. but the build quality looks pretty damned good- all silicone covers over the wires etc..
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
