My mate lost his license for 2 and a half years for drink driving and then got into a chase
He built one about 3 weeks ago and rode it around to my place
He didnt put it on an ugly cheap Kmart bike
It was pretty sick, does like 50-60 k's costs like 6 bux to fill and gets over 200 k's out of it
  • Replies 48
Posted Images
Most people try build this with a whipper snipper engine, way too many head f**ks with that
This whole package comes with everything u need, throttle, petrol tank, everything
I think you have been caught with your pants down when you were sleeping/daydreaming, I think your Farked.
Unless you can afford to hir OJ Simpsons Lawyer.
Good Luck
Edited by OzCarImports
It's gonna kill me if I lose my licence for 6 months!
I've already appealed my licence and was 7 months into the "good behavior" period. Is there anything I can do????
I've heard you can go to court and ask just to drive to and from work only. But I don't know if that's just bulls#%t.
Any ideas???
but i do try to avoid being a dick,
my licence is my job! i loose my licence, i loose my job, my house, my car
every thing i have....is it worth that 20 seconds of fun? no.
but if you do it, and get cought, own up to it, dont pass the blame onto an innocent party.
get a lawyer. and look around. my original lawyer wasnt really sharp when it came to traffic stuff, diddnt realise till end of court. got 15 months. lost business, house, 1 car-expensive 4wd. had to catch the bus to tafe and restart!
being on good behaviour wont be easy to get around.
wish for the best outcome for ya and hope its a reminder to take that bit of extra attention and care on the road
You can do it every 12 months after a successful appeal. I'm fairly sure they dont take into your previous convictions either, so if you wait another 5 months you can reappeal and probably get another good behavior.. or take the 6 months on the chin and get your full licence back.
I'm not sure about the 5 year ruling, maybe if you had an unsuccessful appeal?
Oh and lawyers are anywhere from $150 - $300 p/hr - Will probably only take 30 mins to find out what you need to know.
I'd just go to one and just ask the question, go to a prominent one in the city if possible.
If your paying the money, you may as well get one that knows what he/she is talking about.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
