Hey guys selling my 97 s14a Hispec (electronic sunroof) Im the second Owner its time for my baby to go i have done all these mods, the car was stock as a rock when it was purchased, all mods are about a year old.I got a company car so for over a year i drive it about 3 times a week if that, serviced every 5000kms and only use royal purple oils car is in exellent condition, the buyer of this car will absoloutly love it its got the power,handling and of course the looks and wont have to do any thing else to it.
Got Engineer Certificate.
Engine:
Gt2871R
Tomei step 1 poncams
Tomei Rocker arm stoppers
Apexi Power fc with hand controller
Nismo 555cc injectors
Hybrid Frount Mount
Z32 afm
Blitz electronic boost controller
Greddy turbo timer
Sard Fuel Regulator
Stainless ss manifold
Stainless Cold Air intake
Apexi Pod filter
Short Shifter
Exedy Heavy duty clutch
3inch Turbo back exhaust
243RWKW
Handling
Tein Super street Coilovers
Front Whitline Super Heavy duty Swaybar
Rear Adjustable toe arms
Rear Adjustable Camber Arms
Adjustable front super pro bushes
Rear super pro bushes
Engine damper
Strut brace
19by 8 front and 19 by 9.5 rear Wheels
Interrior
Sard Boost Guage (RARE) got new from japan
Isotto Foot Pedals
Front s15 seats
Rear s15 seat
Custom Red leather door trim and gear boot trim
Razo gear knob
200sx Floor mats
Stereo
Pioneer Head unit
Pioneer 6inch Speakers
fockford fosgate 1xSub
fockford fosgate Amp
Kicker amp
Other
JDM front black grill
Welded and painted boot wing holes
PHOTOS HERE SORRY COULDNT UPLOAD
Pictures in link below arnt good will get good ones this week
http://carsales.com.au/used-cars/private/N...amp;Make=NISSAN
Too much to think of atm and may have forgot few things so plz PM me or Call me for details private numbers wont be answered.
0401 540 266
thanks
Andrew
Located Sydney NSW
140,000kms
$22,000 NEG
Edited by 1SX:2NV
https://www.sau.com.au/forums/topic/233592-97-s14a-one-of-a-kind/
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
