hi guys just wondering i am going thru with the turboing of the car and was wondering if i need to fit a new bar to the car or can i use the existing one. and does the reo bar need to be changed. oww and do i need to get it re complianced under a turbo car???. i talked to the blokes at jis and am getting most the kit cheap, if it cant be done properly it might be time to buy that gtr that looked great in the sunlight, cheers in advance michael.
https://www.sau.com.au/forums/topic/233604-front-bar-for-gts-4/
why do you need to change the front bar and re-compliance you haven't swapped engines if its complied already then leave it if not don't put turbo on wait till its complied
you wont need a new front bar just because you got a turbo installed
but you will want to think about
5stud conversion - for larger choise of rims
GTSt brake conversion - for better stopping
na just make sure its all done good if you ever get pull over only have factory blow off valve make sure POD filter is very secure make it LOOK stock standard and its all good 90% of skylines are turbo (well maybe not that high but very high) so if you do get pulled over chances are they wont know your model isnt
also turbo or not you pay the same for registration
You will have a LOT of trouble insuring a non-turbo car that has been turbo'd. And you have massive costs including injectors, ECU, wiring loom etc etc. Just not worth the effort. Sell it, and buy a Gtst.
Who are you with Steve?
Yeah I guess if it states it on the insurance form then they have no come-back against you.
I would suggest you are with the only insurer who will do it, as I know most won't touch such a car. Until very recently you had ordinary non-turbo brakes and discs trying to stop a high-powered turbo car .... not sure I would like to be insuring you when that was the case ;)
im with Famous and was with Just Cars Prior both were insurerd as GST4 na modified with turbo
yeah about the brakes that's why i didn't go too full on in the hills i had brake fade on 2 occasions and its not nice
    • How's your first born doing? 😛 As for now what? Time to forget about it for 12 to 18 months while your go down a totally unrelated rabbit hole... 😛
    • Fuse taps are perfectly fine to use, especially when you're adding stuff for your own car, and so long as you're being smart about it. IE, don't throw a 30amp circuit, onto a circuit that is only a small circuit. It's best to add a small circuit, to one that is already quite large. Oh, and make sure you're not going to blow the fuses that are further upstream too! I dislike their use in other applications, such as alarms, telematics/tracking devices etc, as it's far too easy for someone to unplug them and render a system useless. Those sorts of devices I go for wiring in quite secretively.
    • Fob is all cleaned up and it’s working well!! The amount of Vegemite looking sh*t that was in there is mind blowing
    • Given it is temporary, I bought a  cheapy gauge mount (which has become enflattened) which I will screw into the existing phone mount Also a first for me; given this is a temporary install I could not think of any reason not to use one of those "add a fuse" thingies to source the battery and IGN power. I had always figured they were pretty dodgy but having a good look at them I think they are a valid option for sourcing power from an existing source without cutting
    • Finally for now, a bit more work on the transmission temp gauge. I was wondering how Raceworks do a gauge for $100 that autometer want $500 for. No idea about the accuracy of course, but they have cut a few corners that made things hard.  First one I mentioned above, the sender is physically difficult to fit and doesn't work with their own adapters (the extra fittings I used to get the sender into a hose cost more than the whole gauge, lucky I had stuff in the shed) Second, the temp sender wires are way too short. They are shown as 2.7m on the box and I know my routing was long from navigator headlight to driver's firewall back to centre console, but I had to lengthen them by about 2m total - 2 joins in each wire. Also, same with the supplied power loom, they needed about an extra 1m to get the fuse box where I sourced power. Another join in each wire since one end wasn't supplied terminated. I know they could argue that the wires might be long enough depending on situation, but when you consider parts and particularly labour, it would be a very expensive cheap gauge if you can't do the work yourself. And, only a small issue....but it would have been nice if they remembered to tap a tread onto *both* spacers they supplied for the bracket....I haven't had to use the M4 tap often!
