hi guys just wondering i am going thru with the turboing of the car and was wondering if i need to fit a new bar to the car or can i use the existing one. and does the reo bar need to be changed. oww and do i need to get it re complianced under a turbo car???. i talked to the blokes at jis and am getting most the kit cheap, if it cant be done properly it might be time to buy that gtr that looked great in the sunlight, cheers in advance michael.
https://www.sau.com.au/forums/topic/233604-front-bar-for-gts-4/
why do you need to change the front bar and re-compliance you haven't swapped engines if its complied already then leave it if not don't put turbo on wait till its complied
you wont need a new front bar just because you got a turbo installed
but you will want to think about
5stud conversion - for larger choise of rims
GTSt brake conversion - for better stopping
na just make sure its all done good if you ever get pull over only have factory blow off valve make sure POD filter is very secure make it LOOK stock standard and its all good 90% of skylines are turbo (well maybe not that high but very high) so if you do get pulled over chances are they wont know your model isnt
also turbo or not you pay the same for registration
You will have a LOT of trouble insuring a non-turbo car that has been turbo'd. And you have massive costs including injectors, ECU, wiring loom etc etc. Just not worth the effort. Sell it, and buy a Gtst.
Who are you with Steve?
Yeah I guess if it states it on the insurance form then they have no come-back against you.
I would suggest you are with the only insurer who will do it, as I know most won't touch such a car. Until very recently you had ordinary non-turbo brakes and discs trying to stop a high-powered turbo car .... not sure I would like to be insuring you when that was the case ;)
im with Famous and was with Just Cars Prior both were insurerd as GST4 na modified with turbo
yeah about the brakes that's why i didn't go too full on in the hills i had brake fade on 2 occasions and its not nice
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
