NSW Photo enthusiasts. The ACT is seeking a photo of a stock looking R34 GTR rear end / left side profile for our skyline banner.
As it is for a banner that we are spending lots of money on, we need to have the copyright on the photo, so it needs to be a photo you have taken that you can authorise us to use. A high megapixel is also requested due to the size of the banner.
We have some great photographers in the ACT but very few R34 GTR’s
Please see the ACT thread for further information.
http://www.skylinesaustralia.com/forums/En...40&start=40
Thank you
Jon
https://www.sau.com.au/forums/topic/233622-wanted-r34-gtr-photo/
We have some great photographers in the ACT but very few R34 GTR's
Thank you
Jon
Hiya Jon,
I'll be glad to supply you a few shots of my R34 GTR taken with my own camera with a Leica lens.
It was also shown with an R32, R33 & the Haltech R35 on NSW Subforums>Members>Surprise Official AU Dyno Day on Aug 16, during a photoshoot.
Can you supply me with an E-Mail address though, since I only know how to send pics that way?
It looks stock with OEM GTR wheels.
Hope this helps.
Cheers, Terry
These were all shot with my canon 400D. I have high res versions if you want. and of course I own the pics, I took them and I own the car! I can easily take some more if you are after something in particular.
Bakes loan me your car (with you driving it) for an afternoon and i'll do some shots for the ACT crowd. :)
Not a problem X Metal, I get my GTC wheels any day now so pics will be better with them on. If the ACT crew want to use my car for pics, they just have to let you or me know I guess.
this is the best i can its a photo i took with my N95 8GB phone and its a pic of a mates 34 GTR just after he was washing it i think i actually got him in the pic too *oops* but lemme know what ya think its the kind of angle ur looking for but feel free to use it and if ya dont thats all good lolz the second pic is another mates 34 GTR
    • That M3 looks like it handles so well, initial slight understeer on turn in followed by oversteer which is cancelled out as steering returns to centre. Looks like such a fun car to drive. In comparison the Skyline and Sierra look like they understeer more and thus need more heavier steering inputs...?
    • Gday   on the hunt for an rb25 gearbox and clutch to go into my R32 rb25/30 build happy to travel a bit or pay for freight for the right one From my limited research, think I need an rb25 driveshaft yoke to make it fit so I’m after one of those too located Bathurst
    • Common for single gauges to be swapped around. My 33 GTST when I bought it had a GTR tacho fitted, everything else was GTST gauges.
    • Google says for a 1998 Nissan Maxima to pull/pry, and the metal pin might even come out with it. I'd do a bit more googling, there was a few videos, find some where the shafts/needles appear most similar and compare the techniques.
    • Details: Turbo Borg Warner EFR 9180 with 1.05 rear housing Upgraded TurboSmart integrated BOV Sanded and powdercoated compressor cover in gloss black Elbow welded with wiggins clamp Speed Sensor(Not included) (Can include oil drain(heat wrapped + titanium intake pipe with almost new filter for a tad extra). Manifold: 6 Boost RB26/30 twin scroll manifold  e-MAP ports drilled into both scrolls(I was using the TAARKS EMAP KIT) Turbo is in excellent condition. Always used Penrite 15w50 Racing oil(Changed less then 2000ks). Also using the Turbosmart OP regulator and filter. Downpipe: 4inch Stainless steel with VBand inlet and outlet clamps(included) Heat wrapped Dual ports for Dyno/Wideband usage Will throw in free 2.5 inch intercooler pipe(2.5inch From turbo outlet to 3.5 inch intercooler) - Powder coated black. Turbo made 563rwkw on mainline hub dyno at around 24-25psi boost - Pump fuel. Will def make over 600kw on e85. Didn't bother as my e-MAP was through the roof with my setup sitting past the choke line. I have a cnc ported and fully built head on my 3.2. Turbine speed saw max of around 109k rpm. I'm running this on my R32 GTR, with AC, and the original power steering pump. The manifold clears the AC lines, ABS, and everything else. Although I had new AC lines because I just wanted new ones and I heat wrapped them as well. This will make more power on a slightly lower capacity motor with a higher PR. And I have since upgraded to a G45-1500. Have pics and videos if need be.  Absolutely nothing wrong with setup. Turbo is in perfect condition. No shaft play or oil leaks at all. All the work was professionally done. The transient response of this is fkn amazing. I cannot rave more about this turbo. If I wasn't chasing 4 figures, I would have kept it. $5000 NZ. Located: Auckland, New Zealand.
