  • Replies 588
Posted Images
ahhh the guy who hit my car and never paid me for the damages lives out there. he threatend to get a restraining on me he i kept bothering him about the money. could be a good reason to head down there.
ill have to check and make sure theres nothing on and ill let you know...
yeah i might put my car in this craig as long as there are bp petrol stations on the way, like u said ill put it on dyno depending who is running it!! i aint havn sum wanker blow my engine on the dyno again!!!
roughly how many km's is it 2 get there????
any1 wanna be my passenger???
good work tim and dan!
you will find the entry form in the first post, fill it out, and ill pick it up with the payment to send it off.
dan, its roughly 1.5 hr drive, there is a bp in pt wakefield i believe....if not, there will be one around kadina/wallaroo etc.
we have 6 cars at this point in time.
dan- R33
craig-R33
Aaron -R32
Rocco- 34
Adrian 32.5 lol
tim-onevia
along with some maybe's
ps, charmaine the photographer was keen for a ride dan
Edited by craig R33
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
