lol shhhhhhh craig.
pretty sure i aint telling you anything anymore either...cos it turns out whatever i tell you gets passed onto adam anyway :(:P haha
anyway ya pics are up that you requesteddd :kiss:
  • Replies 588
Posted Images
just got an email from mark..
he thanks us all for entering and supporting the royal flying doctor service.
and also advised me that the show will be held every 2 years, and will be
known as the ''COPPER COAST SHOWN 'N DYNO
he also asked for feedback, so if you have something you think they could improve on,
post it here so i can reply to his email
e.s.e.p (said in beached whale/kiwi accent) :D
yeah i was happy enough with the way the whole event was run... i thought the country carnies charged to much for there rides but i think my daughter got her monies worth for $5 :( maybe i just forget how much shit really does cost :D
Charmaine, this pic is fckn awsome!
32-33-34 all in one perfect pic... love it mate!
http://fc01.deviantart.com/fs36/i/2008/281...lyhyperlite.jpg
+1! that photo is brilliant!
the blue 32 is very photogenic... :D
same.. peeling bad!
that blue 32 is my mates, thats all it is, a fairy paint job, and he thinks its the best 32 ever :D
he was devo he didnt win best jap or best paint lol...
im glad he didnt win, cos he would have been a sore winner if ya know what i mean
EDIT: he also only had those plates on for the show
theyre not even registred to a vehicle anymore
can someone say POSER?
Edited by craig R33
i think i still had my auto salon 07 sticker on at scs last year haha.
him winning best jap.. chrome and white walls.. puhleeese! its more korean/china spec than JDM.
anyway yeah i rate the show. its like scs before it went shit. i was at the very first show 2 years ago and prob at the next one in 2.
    • She swallowed the spider to catch the fly.
    • Half anticipating the next question then: I have two magnets stuck in my oil pan. What should I do?
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
