  • Replies 588
Posted Images
Yeah I'm tempted but I don't really want to ride the thing that far.
I wish I could tow it in the horse float with the GTR so I could enter both.
A GTR with a tow-bar - i'd pay to see that LOL
I've only ever seen 1 skyline with a trailer, i believe the design of the rear end makes it difficult (but obviously not impossible)
yeah, dont think I'd get too far......the bike would probably tow better than the GTR, lol
Hey everyone,
the folks have given me the A-O-K to coming up just for the saturday (they are a tad bit strict at the moment with me doing year 12), so if i could score a lift in someones car who is only going up for the sat it would be much appreciated. Am happy to drive to the person's house.
I plan to do as i did on my cruise, and fill up a 2g memory card with 500 photos :) hahaha
Maybe not that overboard but im happy to take photos for whoever wants em :(
Hey everyone,
i can give you a lift if you want , im heading up there for the saturday :spank:
    • 1. I can't see a location on your profile but you do mention GBP so I'll assume you are in UK. In Australia, CBC make a timing belt kit with the gears and idler and tension bearing and that is what I use without any problems. I'm sure OEM or HKS are also fine but I wouldn't pay extra for HKS over anything else. 2. Yes, I would always change the idler and tensioner and the stud and bolt that hold them in. Assuming they were all done last time it is highly unlikely you would have a problem, but they are very cheap to add to the job considering the time it will take anyway.  3. No, you don't need to lock them as such (I think that is more for engines without timing marks), but you should make sure they move as little as possible once the belt is off as you can hit pistons on valves if they move too far. As always, make sure you line it all up to top dead centre with the timing marks aligned before you take the old belt off.
    • How to wreak havoc at a bogans party... Swap out the goon bag hanging from the clothes line with oil bag... Watch chaos ensue during Goon of Fortune....
    • Hey everyone,   I’m looking for some advice on replacing the timing belt on my RB25DET Neo-powered 1998 Skyline. The engine was fully built about five years ago, including a fresh timing belt, water pump, and other essentials. However, since then, the car has only covered around 2,000–3,000 miles. It’s currently making around 650hp.   Even though the mileage is low, I know timing belts have a time-based lifespan too, and most recommendations suggest changing them every five to six years or 50,000 miles. Since I’m at that time mark, I’d rather not take any risks and plan to swap it out soon.   A few things I’d like to hear opinions on: 1. What’s the best belt for this setup? Should I go with an OEM Nissan belt, or is the HKS fine-tune a better choice given the power level? 2. Would you bother replacing the idler pulley and tensioner at the same time, or only if they show wear? 3. When swapping the belt, is it necessary to lock the cam and crank gears in place, or is lining up the timing marks enough? I’ve seen different approaches, and I want to make sure I do it right.   The water pump was changed with the rebuild and isn’t run off the timing belt, so I don’t see a need to replace it again. I just want to make sure I approach this the right way.   Any insight would be much appreciated. Thanks!
    • How does this compare to the internally gated g25-550 in terms of power production at same psi and spool
