  • Replies 133
we need more r33's
Currently attending
1. a20089 - r33 GTR
2. OzLeroy - r32 GTR
3. Mark -r32 GTR
4. Steady Eddy -r34
5. Turismo -r32
6. StinkyPoo -r32
7.Michelle -Formula Holden
8.Tarmac -BMW
9. INVRTD -FSAE ws02
Supra's ( i think is unclear on their website )
1. Mazman
2. Kirstel
2. Niko
Edited by INVRTD
Damn it, they changed the forecast again to rain! Can't they just leave it sunny and dry. My shitty tires are almost bald!
I know a guy who can get good tyres pretty cheap :dry:
I'm out again :-( Can't believe my luck, my car died pretty badly on the way to work this morning. Don't know how serious it is, will be checking it out this arvo. In any case i won't be in for this weekend, i'll come and watch though. Good luck team skyline!!!
Little puff of smoke then instant engine death... hope its not the oil pump or a turbo - i didn't hear any major mechanical noises so hopefully its not that bad.
In any case i'm sad, never had to have my car towed.
I'll see if I can enter this arvo, since I do have sdma membership and a cams l2s license. Just need to secure my fire extinguisher I think and thats about it, and turn the boost down. Don't think i'll try real hard on this one.
They're talking mostly sunny for Sunday now, entries close tonight.
You won't regret it, its a lot of fun... and remember, you only go as fast as you're comfortable with, as you're only racing a clock, no-one else.
The launches are fun too :P
I think Shell should do it. We've gotta get Kat out there too.
Ive payed my entry fee, and emailed my entry form together with the transfer details... so im in :P
Never been so go easy on me ay :banana: see you'se all there( ill be with the black supra).
The MazMan is in all the way from Sydney!!!!
So as long as I submit the paperwork tonight and pay? thats enough for now or can I pay on the day?
edit: form says closes 8pm tomorrow
You can pay online and email them the details with your entry forms, you're right, they are closing tomorrow, for a while there they were closing on the Wednesday, but I see their back to Thursday. Payment should be in before the weekend, unless you have made other arrangments with the event secretary.
    • Hi all. So I have my GTR on the lift and have been working on it a few days and today I unpacked the frontpipe that was wrapped with heat wrap stuff, because part of it was breaking down and soaked in oil. Noticed that the pipe itself does not actually look like a Mines, despite it supposedly being a Mines. But I could not find any fronpipe online that looks exacly like his, and I don't think it is a custom one. My amateur measurement also showed the two pipes are about equal length, so maybe this is just an old version of the Mines pipe? Would appreciate insight on this by the enlightened folks. greetings from Germany
    • Yeah. If I plug the connector in and connect the vacuum lines, I assume worse case scenario is that it simply doesn't work? Yep PFC.
    • I would think that rather than attempting to perform an engine swap, with all the difficulties associated with doing so in a country where the raw materials required are harder to get hold of, I would just build the CA20 for boost, find an EFI manifold for it and either add a turbo or a supercharger. Or both. You replace one set of difficulties with a different set, but I know which would be more fun.
    • Well, a proper aftermarket ECU** SHOULD be set up to run the purge solenoid, same as the factory ECU would, so that the tank breather system continues to operate the way it is supposed to. I have no knowledge of whether the PFC (which is what I assume you mean when you say Apexi) has an output (and internal logic) to run the purge solenoid. If it does not, then given the product design intent for the PFC, which is to be a plug in replacement for the stock ECU, I would consider that a massive failing on Apexi's behalf and would be another reason to think that they were a half-arsed solution to the problem if programmable management on RBs. I would suggest that since Nistune came to market (which is a LOOOOONG time ago now) there has been no valid argument for choosing a PFC, especially if the PFC can't do things like this.   **ie, Haltach, Link, Motec, etc
    • Thanks for asking the question we were all thinking!
