Well if its a day cruise i will be there. Night time is not the best of times to have performance cars parked up at Koondoola shopping area unless its all changed since last time i been there. I grew up in Girrawheen so familiar with the troublesome area's.
Cheers.
  • Replies 55
we'll only be there for about 20 minutes to eat and stuff then go for the cruise...
thing is, there isn't too much seating so yeah i'm also assuming a few people will be standing outside with our cars anyway...
will be awesome to catch up with everyone as well as meet new people, and yeah... my family has run businesses there for YONKS and trust me, not much has changed lol
did i hear cruise and dinner?? i'm up for it! after this thursday though..still having my exams..and my gf will be here in oct so definitely good to meet up with you guys :banana:
okay guys, i'm going to be sending out details and invites tonight via pm...
if anyone else is interested please let me know so i can get a specific number to make life easier for my sister...
look forward to catching up with you all soon!
cheers!
Andrew :(
cheers!
Andrew :ninja:
Dont forget to send one to me :)
Greg... i'll send you all the details tomorrow mate if you can just pm me your email?
hey Coz... yeah she's got a few flavours, like maybe 30-40 or something from the top of my head, but like you can make random 'fusion' flavours if you like ie. 'Mango Peach' or whatever so really, the Bubble Tea flavours are endless with your imagination!
hey John, thanks for coming down... when i wasn't there! glad you enjoyed the food man, hope you can make it on Saturday...
thanks for the comments peeps, keep them coming!
Andrew ;)
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
