Item: RB26 Power FC
Age: Unknown
Condition:Excellent
Price: $800 plus post
To Fit: R32/R33 GTR - Can be modded to suit RB20 if buyer is keen, at extra cost.
Contact: Reply or PM
Comments: Comes with Gold 'Limited Edition' D1 Hand Controller
Item: Z32 Air Flow Meter
Age: Unknown
Condition:Working Order
Price: $200 plus post
To Fit: Most Nissans
Comments: Comes with Plug
Item: Exedy Brass Button Heavy Duty Clutch
Age: 1000kms old
Condition:Next to Brand New
Price: $600 plus post
To Fit: Most Nissans - Rb20/Rb25/Rb26/Rb30 - Push Type Clutch/
Comments: Comes with Custom Pressure Plate (Cant remember Specs) & Matched Flywheel (Machined when clutch was installed) -
Complete with all bolts required. and Trust Bearing. Was Removed for Auto Conversion.
Clutch plate has 8.04mm left of material after 1000kms - Exedys listings state they are only 8mm from factory
Thanks for looking. Will post pics ASAP.
Can Post at Buyers Expense.
Can do drop/deliverys in Melbourne Area - PM me.
Do you still have the AFM & Plug - whats the best you can do - how's $120.00 and i'll come pick it up tomorrow cash..
Cos you dont know what condition its in.. Have a think and let me know,,
Cheers.. Im just in FootsCrazy so not far ..
Dee..
    • Just a follow-up on this topic. From what I can tell so far the rusty residue on the engine block might be unrelated to a coolant leak or maybe just older than anticipated. After driving it from the winter garage to my friend's garage I could not see any new traces of coolant leaking there, but I will test this properly once I was able to fully warm up the car and drive it for a bit. I think I can agree that the whole porous engine block stuff is kind of nonsense, but there is just a silly amount of true, false and half-true information on anything Skyline-related on the internet.
    • hrmmm , not mine , easter plans to pull engine not happening
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
    • Quick update.  The engine grounding strap was replaced, the engine is now happily running.  Tested the voltage drop before replacing the strap, was about 1.2ish volts down between engine to battery, chassis to battery. With the new grounding strap, pretty much no voltage drop at all.
