Had that Billy Connolly song in my head. :P
Well I've filled out the application for divorce papers today and I'm lodging them with the Family Court. I'm moving from the "separated" status to the "divorced" status ... oh goody, a whole new box to tick when I fill out forms now. :D
It becomes official in about 90 days from today. Naturally, my GF is ecstatic! :D She doesn't feel so bad now, sleeping with a married man :)
So, anyone else out there who is a divorcee? Let's unite! :D
I'm going to get hella drunk this weekend to celebrate!!!
https://www.sau.com.au/forums/topic/233671-d-i-v-o-r-c-e/
It is when its a cheating wife I'm getting away from. :D
suppose so..
but its still a bit sad when u get 'congrats' for a divorce.. but thats just me! guess its an awesome feeling to be moving on properly!
https://www.sau.com.au/forums/topic/233671-d-i-v-o-r-c-e/#findComment-4096246
wooohoooo! We need a "Ruby's life" forum, housing opportunities, relationships, you could be Australias answer to Dr Phil!
Well since big brother got taken off the air, its a perfect excuse to trot out the cameras.... anyhow grats ruby
-D
https://www.sau.com.au/forums/topic/233671-d-i-v-o-r-c-e/#findComment-4096258
Dr Phil? :D LOL
Don't come to me for advice ... I'm only wiser because I've made mistakes :P
Anyways, I'm the one who suffered and lost almost everything because of the ex, so if I can find some humour and relief in it, then its all good. :D
https://www.sau.com.au/forums/topic/233671-d-i-v-o-r-c-e/#findComment-4096268
exactly
same goes for my knees
just trotting out some random thoughts, not caring who reads or answers how, can help in a minute way mentally
congrats that the end of the previous relationship will be finalised, good luck with moving house
kiddies soon? and a autech to carry them in?
my stag is all finished now. my marraige isnt lol !! ups and downs, for us its all about the kids. and honesty :D
https://www.sau.com.au/forums/topic/233671-d-i-v-o-r-c-e/#findComment-4096326
The kiddies topic was one of the many things that led to the divorce. Hopefully the GF will provide :D
As for the Autech ... wouldn't you like to know :)
Don't sweat the pressures of marriage. The ups and downs are what strengthens the relationship. My ex and I had many ups and downs, it was the lies in the end that killed it. Doesn't matter how bad anything is, always be truthful to your partner. :D ... but you already knew that :P
Edited by RubyRS4
https://www.sau.com.au/forums/topic/233671-d-i-v-o-r-c-e/#findComment-4096330
    • Yep I will use a guide coat after putting filler, I will do it on the whole panel as I'm a beginner so chances I've made quite a few errors. In that photo, I think that was a low spot, I just for example said to pretend it's flat but I will put filler + guide coat after to assess where I'm at. Yep with that picture, the panel is wet as it rained when I took the photo. But all those scratches are completely smooth, I went over it with 240 grit and can't feel it, even with my nail digging into it. I was legit thinking to buy a 2k can and spray primer to see how it turns out but then thought to myself it's going to be a mess doing it haha. Good mention there. Thanks for all that info I think I know what to do next.
    • Prior to laying down the primer, you need to make sure the surface is completely level. For example, based on this picture, I strongly suspect that the areas marked in blue are higher then the area marked in green.  If you spray primer over this entire area, then paint and clear it, the finished result will 100% show the low area. It will stick out like dogs balls. Unfortunately the paint won't magically level out the low areas as you lay it down.  Without seeing it in person, I expect that the green area will need to be filled, then use a guide coat and check that the entire repair area is level with a large sanding block.  With this picture, are you saying that even though you can see the scratches, the panel is in fact completely smooth and flat? If this is the case sure you could prep and paint it as it is.     The picture with the paint you described as blistering, it's hard for me to comment on from the photo alone. It looks like the panel is wet? Dunno, looks strange. Does the panel feel as smooth as glass when you run your hand over it? **** Going back to your question again, generally you would only sand the primer if you made a mistake while laying down the primer.  If the panel is prepped properly and you lay the primer down properly, you should not need to sand the primer.  This wouldn't work - Don't prep the panel. Spray primer and see how it turns out. Sand the areas where the issues appear. Spray more primer and see how it turns out. Sand the areas....... Yeah you'd go round and round in circles getting no where.
    • That's sick, thanks for that, mine has much the same mods on a 400R. I just don't have the heat exchanger yet.   Might be worth a trip down the M1 to Syndey for a tune.
    • Mate , this is the current mods list Current Mods list (Installed) RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Cat Back  RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Front Pipe AMS  - INFINITI Q50/Q60 RED ALPHA COLD AIR INTAKE KIT AMS  - Performance Heat Exchanger Intercooler AMS Alpha Performance Full Race Down Pipes ECUTEK tune form TuneHouse in Sydney .(Just over 2k) The car came with HKS - Power Editor but I had it removed for the full tune. I would say if you are using the car for street diving a proper tune would be better.
    • Interested to see any videos of this or on the dyno. Mine currently has HKS secondary cats i am undecided if I want to remove them. What did it set you back to get the tube done? And what mods have you got to get that power? I was looking at a racebox flash tune but maybe a proper tune would be better if these guys are good.
