Jus a quick post as my V35 is due for pick up very soon , i'll havew some pics up when i get it (STOCK).
until then i need some help choosing wheels!
I've already decided in 20" wheels(Staggered) but i need help on opinions.
the car is silver so i was thinking maybie a darker style rim? but maybie not black?
Price preferably under 3K but might stretch abit over if its a really nice set..
I've found a set of Vertini - Hennessy wheels in 20x8.5FRONT(2.5"Lip) and 20x10REAR(4"Lip) which look ok in the picture, but i'm having a little trouble picturing them on the car! these are available for $2950. Pic attached
Sorry im not sure about the offsets!
If you guys could let me know what u guys think or have any other ideas that'd be great!
Thanks in advance
Kari
Of course the car will be lowered pretty far with coilovers also :(
https://www.sau.com.au/forums/topic/233711-wheels-to-suit-v35/
Nice looking 20 inches. Wonder what will be the tyre size though...
Well I'm planning to get this in 19" staggered set... I'm trying to keep it sensible and not too big, just in case the 20s are not lightweight.
Sportec Mono10, a common switzerland rims for Audi/Porsches. Managed to find one in 5x114.3 pattern.
nice looking rim, very tidy and not too over the top, would go well with the look of the car.
me personally am looking for somthing with abit more dish.. but those wheels your posted would keep well with the look of the v35 :)
kari
few things to consider:
1. the v35 is already a pretty heavy vehicle. 20s will add to the unsprung weight. Consider lightweight forged jap 19s?
2. 20s + coilovers is going to compromise your handling and comfort. Choose your spring rates wisely.
3. If you are patient, try and source a set of used jap 19s or try the traders on this forum. 3k should net you a decent set. The v35 is in a similar league to 3 series beemers, c class mercs and lexus...I believe they deserve nothing less than a nice quality set of wheels :blink:
At the end of the day its your car though, so stick with whatever u like.
i am currently running TEIN Comfort Spec Coilovers on the V35 they are awesome for the ride quality
i just ordered a set of these for the v35 in 19" [with guard hugging offsets] should be here in 8-10 weeks:
the Volk GTC's i have on the car will be up for sale soon once these arrive
Edited by BLISTC
If you have the coin to spare, there's a trader on JDM Style Tuning using the nick "thetunersgroup" who is the official importer for HRE Wheels.
They come in a similar style to what Kari wanted in his original post, and they're very high quality.
Kari - I'd also suggest gettin 9.5" wide front rims for more phatness in the dish, unless you can get those 8.5" rims in a custom offset.
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
