l0WRB Posted August 28, 2008 Share Posted August 28, 2008 (edited) posting on behalf of a friends r33 which has serious problem mods rb25det series 1 splitfire coilpacks cooler exhaust 10psi stock ecu items we have tried and replaced with items off my car. afm 3 different fuel pumps, now running stock rb25 fuel pump coil pack igniter cas fuel regulator basically im gonna try best describe what the car does. sometimes the car will drive fine for half a day or all day then all of a sudden the car will start surging just while driving along at 60kmph or 100kmph this is when the fun begins, once the car starts surging it will basically just cut the ignition and u have to put ur foot flat to the floor to keep the engine going, thing is the car doesnt rev or go anywhere with it flat to the floor, u can hear the turbo spooling and the bov goes off a bit but the motor isnt reving or accelerating and thats flat to the floor for about 20-30secs, and if u take ur foot off the accelerator the car will die and u have to roll over side of the road and kick it over 3-4 times before it will go again. the fella has a powerfc there aswell that he has tried plugging in and using on base map but it does the exact same thing. does anyone have any ideas? we r out of ideas. have tried replacing the above items but nothing has fixed it. Edited August 28, 2008 by l0WRB Link to comment https://www.sau.com.au/forums/topic/233713-serious-problem-with-r33-gtst/ Share on other sites More sharing options...
race_snooze Posted August 28, 2008 Share Posted August 28, 2008 fuel filter. Plug gaps, broken plug under heat, hose's (inlet, intercooler, vacuum) bad earth! Bad electrical connection, dirt in connectors in the ignition side Link to comment https://www.sau.com.au/forums/topic/233713-serious-problem-with-r33-gtst/#findComment-4097075 Share on other sites More sharing options...
OVADRV Posted August 28, 2008 Share Posted August 28, 2008 What do you mean it just cut the ignition? Link to comment https://www.sau.com.au/forums/topic/233713-serious-problem-with-r33-gtst/#findComment-4097081 Share on other sites More sharing options...
l0WRB Posted August 28, 2008 Author Share Posted August 28, 2008 well the car u have to hold the accelerator flat to the floor to keep the motor from stalling and u can hear the turbo spooling still but the car doesnt accelerate or go anywhere like uve got it in neutral, and if you just let your foot of the accelrator the car will die and wont start again until u pull over and kick it over 3-4 times. Link to comment https://www.sau.com.au/forums/topic/233713-serious-problem-with-r33-gtst/#findComment-4097103 Share on other sites More sharing options...
l0WRB Posted August 28, 2008 Author Share Posted August 28, 2008 (edited) fuel filter has been replaced, plugs has been replaced, vacum leaks have been checked all clamps. havnt checked for bad earth or anything? only thing i cant think of that is earthed is ya igniter pack? hmmm pretty sure its all bolted on near towards coilpack no6 its really fkn hard 2 guess wot it is though the car starts and runs perfect and then all of a sudden it will just do this out of the blue wether u flog or baby the car. Edited August 28, 2008 by l0WRB Link to comment https://www.sau.com.au/forums/topic/233713-serious-problem-with-r33-gtst/#findComment-4097115 Share on other sites More sharing options...
RBwhatever Posted August 28, 2008 Share Posted August 28, 2008 So you've checked all the cooler piping and joins? When my pipes partially blew off it wouldn't rev past 4grand, wouldn't make full boost obviously but was still spooling, it was just a massive air leak that would only open up under pressure. Off boost it drove fine. Made the car run pretty crap though under boost. ....ummmm blocked cat maybe? Link to comment https://www.sau.com.au/forums/topic/233713-serious-problem-with-r33-gtst/#findComment-4097131 Share on other sites More sharing options...
l0WRB Posted August 28, 2008 Author Share Posted August 28, 2008 (edited) yeah its not a vacum leak or join the car WONT accelerate or make any boost, but u can hear the turbo spooling as u hold ur foot flat to the floor for 20-30 secs. car doesnt DO ANYTHING at all cept roll along, its messed up. car is running gutted cat. hmmm Edited August 28, 2008 by l0WRB Link to comment https://www.sau.com.au/forums/topic/233713-serious-problem-with-r33-gtst/#findComment-4097145 Share on other sites More sharing options...
Al Posted August 28, 2008 Share Posted August 28, 2008 If the car is lowered remove the front right wheel, then the guard cover, and check to see if the loom as been damaged by the wheel itself. I have seen lowered cars rub through the looms and create massive shorts and problems. One even caught fire and the loom had to be replaced. Is it more likely to happen in the wet, hot days, after X amount of driving, on rough roads, etc. Also make sure you carefully check all the wiring, especially in the engine bay. Link to comment https://www.sau.com.au/forums/topic/233713-serious-problem-with-r33-gtst/#findComment-4097153 Share on other sites More sharing options...
l0WRB Posted August 28, 2008 Author Share Posted August 28, 2008 Ok thanx AL i will check that as soon as i seem him next, prob 2morrow and yes the car is lowered alot and front inner guards tend to rub alot when goin driveways etc Link to comment https://www.sau.com.au/forums/topic/233713-serious-problem-with-r33-gtst/#findComment-4097166 Share on other sites More sharing options...
cameron Posted August 28, 2008 Share Posted August 28, 2008 Sounds like some sort of wiring issue... unlucky! providing you have changed everything you mentioned... Link to comment https://www.sau.com.au/forums/topic/233713-serious-problem-with-r33-gtst/#findComment-4097596 Share on other sites More sharing options...
robots Posted August 28, 2008 Share Posted August 28, 2008 Does it puff black smoke when he floors it ? Check this one for sure. Link to comment https://www.sau.com.au/forums/topic/233713-serious-problem-with-r33-gtst/#findComment-4098205 Share on other sites More sharing options...
l0WRB Posted August 28, 2008 Author Share Posted August 28, 2008 thats one thing we are yet to find out robots, i might follow him and find out, bit hard 2 notice anything in rear vision mirror, ill get back to you on that ok:) thanx guys Link to comment https://www.sau.com.au/forums/topic/233713-serious-problem-with-r33-gtst/#findComment-4098264 Share on other sites More sharing options...
enilyks33r Posted August 28, 2008 Share Posted August 28, 2008 (edited) I had a very similiar problem, but mine restarted on first try, it was dry solder joints in the AFM. Re-soldered joints and all fixed. It sounds like it the AFM to ECU harness. Edited August 28, 2008 by enilyks33r Link to comment https://www.sau.com.au/forums/topic/233713-serious-problem-with-r33-gtst/#findComment-4098435 Share on other sites More sharing options...
