hey guys, im trying to change my gearbox oil on my R33. For some reason i just cant get the drain and fill plugs undone, even with a breaker bar. Anybody had this problem?? Also, i know its on here somewhere, but what clutch would u recommend for a 250rwkw car for everyday driving? Plz help..
https://www.sau.com.au/forums/topic/233723-what-clutch-plus-help-changing-oil/
I saw that, but if you want a good clutch Jim will build it and will probably have a recommendation of installer in your neck of the woods, Order it from up here, get it put in down there- too easy.
I have recently embarked on this exact same thing, clutch investigation myself. One name kept coming up again & again.
Even a family friend who builds extreme high powered street bommadore's told me not to waste my time anywhere else when I was quizzing him on installing one for me cause I'm too lazy to do it. The first name he said was Jim Berry.
My middle brother who is building a 700+hp evo3 is going to use Jim.- He found out about Jim years ago when he built an Evo2 & used one then, and when I mentioned a shudder in my 32 when taking off not long ago he said Jims name straight away
So its up to you bud- was just trying to be helpful
Sweet as, hope you get it sorted,
Another option for the gearbox plugs is to put a piece of pipe on the end of the breaker bar to extend the length and give more leverage.
make sure you have stands under the car to stop it falling on you if the jack moves. Be really careful there.
How I did mine was to drive the car up on 4 pavers- 1 under each wheel so the entire car was higher and remained perfectly flat.
Undo the filler first
Then the drain plug & drain box
Apply Locktite or thread tape( I used thread tape) & replace the drain plug, tighten then refill with gearbox fluid.
Hope this helps :(
I would highly recommend looking into clutches that have anti burst covers...
250rwkw there are definitely plenty of off the shelf items like Excedy that will be more than adequate for holding your power level Kudos Motorsports sell the Genuine kits on this site in there trader section and are great to deal with
Also drop Dan from Elite racing a PM (3lit3 32) he has some Tasty NPC Clutch packages that come with with billet flywheels
Good Luck!
  • 3 weeks later...
    • Do the following first and get back to us. - Clean and verify your IACV - Verify for vacuum leaks/post MAF leaks. (Pressure test is the best and cheapest way) - Do you have a BOV with stock ecu/MAF? If so, remove it.
    • Hey all, The skyline I have is stalling when the engine is at normal operating temp.  When starting it while it is cold, it'll run just fine.  I have replaced the battery (bad cell), I have replaced the fuel pump, fuel filter and clean the MAF sensor.  Any other suggestions?
    • Thanks for all the information on this.  I tried ordering the parts from Amayama website and all 3 Solenoids are discontinued and not available.  Does anyone have any other websites to suggest that I could find the parts?   Separate issue-- I will start a new thread, but basically the vehicle is stalling when warmed up.
    • It's unfortunate what Tomei USA has done to Tomei's name in general. I'm very weary of ordering parts from them now. I only order direct from a Japanse source (e.g Nengun). At least their logos are different, so you end up knowing what you have.
    • Update Issues 5 (plus #4) - 10 After making a claim about issue #4's missing part, DeAgostini Japan sent a whole new issue #4 and it arrived about 2 weeks after that. That was back in early March. It took another 4 weeks to receive issues 5 - 13 though. This update is for issues 5 - 10. Ove the 5 issues the front left suspension and most of the engine have been completed. The quality of the castings and fit of the parts is quite good, it seems better than DeAgostini's BNR34 Skyline GT-R from the Fast & Furious 2 movie, which (to me anyway) doesn't seem to have as tight tolerances or quite as accurate castings.  Each issue has a lot of info about the 1989 - 1993 Skyline range and other Nissan models from that era, but the focus is on the BNR32 Skyline GT-R Nismo and the various racing it did in Japan, Europe (Spa 24hrs) and of course Australia. I've included some text translated with Google Lens in some photos and will add to them if there's anything worth including.
