first i sanded the parts with wet and dry sand paper by hand. i used three different grades, i think they wher 800 through to 1200. them use a stitch cotton mop(buffing wheel) on a bench grinder,(has to be at least an 8inch) use the stitched mop with a brown buffing compound. then once you get a shinny finish u use a different buffing mop(loose leaf) with a white buffing compound. and u can get it a shinny as i did.
u also need a spindle (adaptor) for the buffing wheel to fit on a bench grinder.
guys remember this takes hours to get the result that i got.
8 hours to do the rocker(cam) covers.
6 hours to do the intake pipe.
1/2 hour to do the CAS
and about 9 hours to do the plenum.
and this is only polishing time. not removing or fitting parts back on.
r31 skyline chick
ur plenum looks really good, who did you get it done by?
i was thinking about going in to business for myself and doing polishing full time. what do you guys think.
how hard will it be to mainttain that shine ? coz im getting my intercooler piping re-done in stainless so looking to shine up the engine bay... im willing to spend time into it, i dont have a bench grinder, rekon there's any other way for me to do it ?
DJ_L3THAL
i wipe it over every time i wash the car and give it a light polish by hand about every 3-4 weeks and still looks as good as the day i did it.
deffinetly cant do it unless u have a good bench grinder!
you wont even be able to use a angle grinder because u need the loose leaf mop to get the best shine. you could always do it by hand, but you would have to do a lot more sanding, and it would take you an eturnity.
Originally posted by walkoau
r31 skyline chick
My other half does all my polishing.
And my metal fabrication, and all the other fun stuff that I can't do by myself.
I do the painting and ricing and cleaning.
I think it's fine.... as long as you don't mind getting dirty.
It's probably not as viable as it sounds.
Some things can be an absolute bitch to polish, my plenum has at least 8 hours work in it, and it still isn't perfect.
You need to take into account that if something so small takes a whole day to do, will people be willing to pay you a whole days wages just for one little shiny bit?
r31 Skyline chick
yeah iknow what ur saying, but i dont mind getting dirty, im a heavy vehicle/plant mechanic by trade so im always dirty anyway.
DJ_L3THAL
i have no idea how much a pro would charge to do it. id imagime it would cost a fortune, but they would have all the right gear and get it way better then mine.
also i personally dont like the blue on my hose and wiring! i want to purchase some blue silicon hoses to replace the black one and get rid of the blue plastic.
rb20-calais
pm me. let me know when you want it done. if you can remove and refit ur self?
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
