Hey,
Some mates and I are going to be carrying out a engine conversion on a s13 silvia very soon... putting a rb26 into it. And just wondering what to do about the front sump. I was going to fab a plate to cover up the transfer case on gearbox. I havent had a look under the GTR yet to see what the front sump is like but from what i gather we will need to remove the diff etc... or want to anyways to save weight... so there will be a hole in the sump?? How do people get around this... does a rb25 sump fit it? or just weld the hole shut
cheers
https://www.sau.com.au/forums/topic/233752-rb26-into-s13-silvia/
26 sump is the way to go, just cut the diff off and spin up some alloy bungs to weld into the sides. We run a "c" section in the front corner to clear the big sway bars we run too.
MAKE SURE YOU FIT A BAFFLE (std one is shite) AND DRILL OUT THE OIL RETURN HOLES IN THE SUMP......
oh thanks heeps, where abouts are the oil return holes?? Are you talking about the holes in the baffle in that pic... or are they not pictured?? Also what size do you drill them out too... and as for the alloy bits you weld in... is it just the 3 holes i can see on the side? That shouldnt be a problem as ima fitter and turner, i have access to all that stuff.
Have you got any pics of modded baffles you use??
thanks heeps
also will the sump clear the standard sway bars? How thick are yours that you run?? Is it not possible to fit any larger than standard sway bars with rb26 sump??
i use the Tomei or NISMO baffles. The std baffle is pretty average.
There are only two holes to weld up and they are the ones the shaft travels through. Also remmeber to fill the engine oil up to the bump on the dipstick above the H (oil cooler would help too). They suck the sump dry pretty quick.
i have marked the holes to drill out below :D
any sump pretty much fouls on a a/m sway bar. I run bits and peices from diff cars on our race car (R32 lower rad support, sway bar mounts, castor brackets etc) to get the best positioning of the engine and radiator etc... The Rb26 S15 im building atm is pretty much R33 from the firewall forward and R34 GTR from the rear doors back.
alrite thanks for that, been very helpful, have you got any pics of the "c-section" your talking about?? Would be interested to see how u made it
Edited by choku_dori
ok nice, so do u just put a piece of angle line in there?? what size do you usually use and thickness?? eg 25x25x3mm?? Also how do u weld the sump, with a tig??
after having a look around i see greenline.jp have the baffles etc.. quite expensive for what they are but i guess they are good insurance. I will probably go for the tomei one cause its the cheapest there coming in at $200. There is alot of choice, but they go up to $600!!!
I get a mate to tig it up, make sure to clean it thouroughly first though. i used 4mm as we have bounced the sump at certain tracks....dam tassie and their monstrous ripple strips (these pics were taken as this was my second sump) the original sump was killed in tassie..... was glad it was not sheet metal like a rb25 or it would have destroyed alot more.... a bit of knead it got us back on the track.. just enough to fill in the crack.
ok thanks heeps!!! ill keep my eye open at work for some 4mm angle line :( ill try get some pics and post up a tutorial on step by step photos how to do this, im sure others will find it usefull too
Stock RB26 baffles etc are good enough for GTRs, with 4WD, with semi comps and over 300rwkw SO....
Will be enough for a S13 with no traction if you put enough oil in it to begin with.
I run a modified RB26 sump also, just cut out the diff section heavily and its fine from there.
You might have to trial fit to make sure you knock enough off.
i agree if it is just a street car but we found the driftbox showed far harsher extreme directional (switchbacks) g-forces when drifting at than when we had the semis on doing a practice sprint day, the amount of burnt cranks in rb's from surge in s-series chassis is testament enough to use as much preventative equipment as possible, we run around 8.5 liters in our race car and the new dry sump setup for the new car runs more.
If your doing run of the mill stuff, then dont bother but for the sake of $185 for the tomei unit it is cheap insurance especially if yo do end up modding the sump to clear the sway bar as it takes around 400ml away from the sumps capacity.
http://www.racerindustries.com/store/index...products_id=613
  • 7 months later...
Dodgy paint pic "P
I know its an old thread but.......
I'm in the process of fitting a Rb26 in a C35 Laurel, an would like to know if this "L" section in the crank case is absolutely necessary to clear the original sway bar???
I assume that S13/S14/S15/C33/C34/C35 run the same suspension set up in the front in terms of the sway bars and power steering rack?!?
I'm prepping the engine so when i'm ready it will be just a matter of taking out the 25 and putting in the 26 rather than having to trial fit the 26 and take it back out again to seal up the sump, so and feed back will be greatly appreciated. :)
I've seen the Japs use welsh plugs or water jackets as we call them to seal the axle holes, what do u guys think of this method?
should not need the section, im putting a 26 in my c34 laurel as we speak.
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
