If anyone knows of this person, dont even bother dealing with him cos after he gets the money you wont hear from him again. I lost out through ebay on $110 which isnt much but its the principle of it. Won the item end of June, paid in July, and reported it to ebay earlier this month. Apparently he is from the Seaford area but i cant confirm. his seller id was 123_jase but its been deactivated. Just a heads up for everyone to watch out for the low life degenerate theif.
https://www.sau.com.au/forums/topic/233772-does-anyone-know-sam-geri/
Yeah, that's the thing... call me traditional, but can't touch it and see it in person - buying over the internet is, to some degree, still risky.
However, using Paypal is good - it does give you added security as everything is done through Ebay's third-party preferred Paypal.
You can call Ebay now, so I would call them up and seek assistance.
paypal are the biggest scammers known to mankind. no thanks, i'd rather rub honey on my genitals and sit on top of an anthill than deal with paypal.
i must try that
sorry to hear you got scammed G - i agree with spunky_monkey - i too try not to buy anything online, if i cant touch it, then i dont buy it....rarely anyway...unless its a reputable online store (e.g just jap)
Every dodgy transaction I have had through paypal has been refunded almost straight away when buying from ebay...not many however.
Pay Pal stink!
I bought a used mechanical part (HKS branded) on Ebay using Pay Pal, good arrived, the PART fail to work, i logged my claim.............emails forward and back.........Seller rang me up from OVERSEA with abusive languages......Seller left abusive message on the logde centre in writing. At the end......
Pay Pal asked me to send the Part to HKS to have it certify that its malfuntion, i told them its a joke and don't worry about it.
Was this seller's feedback rating really low?
How did you pay?
Ebay can be a bit dodgy when it comes to getting your money back or making a complaint, paypal is better but its still owned by ebay anyway...
paypal are jerks, brought a $250 item, not only didn;t the seller send it, but he had a false home number and address so i couldn't get in contact with him other then email (which he never replied anyway). i claimed, paypal found it in his favour and i lost out...and 250s a lot for a full time student...
I freaken hate PayPal. I can't even sign up any more because apparently my old credit card numbers are on the system which I cannot find and they wont let me set up a new account with the same numbers. Bahhh...
How did you pay?
nah it was like 98% or thereabouts which isn't too bad. i had to pay through internet banking.
stop buying more useless items from ebay glenn.... :P
get stuffed jerkface, this is the item YOU told ME to buy! so technically, you owe me $110 calvin!
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
