would recommend Autoworx or Xspeed, people who do this quite alot
or how good are you with your hands? If you've got all the bits you could do it yourself.
Did mine myself, not too shabby, a few f*ck ups but thats how we learn, haha
https://www.sau.com.au/forums/topic/233780-fmic/#findComment-4097991
Yea... do it yourself and save heaps of money. Just take your time with it and be sure you got it all right. You have to cut one hole in the chasis for the piping to go through and might need to take a tiny bit out of the bumper, but hopefully not.
https://www.sau.com.au/forums/topic/233780-fmic/#findComment-4097997
series 2 + greddy fmic... he will have to cut a hole and trim the bumper.
I say do it ur self... i did mine my self as well. But i installed a stealth FMIC, so no cutting required.
However, most work shops like xspeed, c red, tenagah can do it for u for few hundred.
Edited by br3ndan
https://www.sau.com.au/forums/topic/233780-fmic/#findComment-4098007
Just to add, it did cost me a carton.
The intercooler I have was too thick for the metal support behind the bumper so I marked it out and took it a panel beater, he cut it perfectly and sprayed it for a carton of TED's. (tryed cutting it myself but it was too much for the little ozito anglegrinder lol).
https://www.sau.com.au/forums/topic/233780-fmic/#findComment-4099854
cheers guys for the help.. i managed to fit the intercooler my self... i have a problem but.. when i drive hitting around 2.5-3000 rmp the car chokes like ur bunny hopping and spits like (backfiring).
ive only done the intercooler.. havent got no boost controller or gauge. also i heard something about spark plugs..
any ideas?
https://www.sau.com.au/forums/topic/233780-fmic/#findComment-4102859
any ideas?
plugs or coil packs
most probably coil packs . gap your plugs down to .8 or lower but it will probably only help temporarily . then buy some splitfires
https://www.sau.com.au/forums/topic/233780-fmic/#findComment-4103221
gapped the plugs to .8.. went for a drive down the street and struggled to get back into the garage.. heaps of jerking and feeling like the car gonna stall..
damn intercooler.. grrrr
Wogan where abouts is the Cas?
Dukes.. ive got a stock BOV
btw mods = Xforce exhaust system and pod filter...
https://www.sau.com.au/forums/topic/233780-fmic/#findComment-4105596
it's a bit of a long shot, but check that when you fitted your return pipe you didn't knock the plug in your CAS .. i had a problem with a loose wire in mine once and it caused the same issue.
Checked the Cas plug.. feels firms and secure.. its the round thing in front of the engine where now the intercooler runs on top of it hey
https://www.sau.com.au/forums/topic/233780-fmic/#findComment-4105618
U sure theres no leak with ur intercooler piping??
Everything sealed up?
Yeah found the problem br3ndan cheers buddy. i checked the intercooler piping like u said and i found that the hose connection that connects the pipe to the intercooler under the headlight wasnt covering fully and probably was leaking from there.
i feel like a fool now :P
https://www.sau.com.au/forums/topic/233780-fmic/#findComment-4107768
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
