  • Replies 95
Turned up at vilis with the mrs,didnt really know anyone but roo,so we stayed for bit them went home,both heaps trashed from work :) ,keen to come along on cruse again,maybe if any random cruses happening next fri let me know,got few days off so keen to go out,otherwise try to get to calender days :( ,didnt check fri before going out,to see lil miss33 cruse maybe next time
Edited by tryandcatchme
HAHA I know... i don't think people quite believe me when i tell them is ACTUALLY knocks photo frames of my wall when ben starts it... LOL
HAHAHA oh i'd beleive that!!!!! I couldn't hear my car the other week when we were following ya's!
was good to acutally get out and go for a drive other then driving to work and home :(
got abit scared cruising to the bay so took a side street. im really scared of cops :s
also good to meet new people and to catch up with the all the people i already knew!
u missed alot of fun on anzac :)
i was the gtr in front of you all the way to the bay before you rocked up at kmart carpark :)
wheres the pic of my car angerman :( or was that Min's camera?
I got a lil loose on the exit from Vilis, sorry about that guys, i haven't driven it properly in a while :)
Sorry man, the photo was blurry-as and I didn't think it was worthy. I will post it up though when I get home.
Turned up at vilis with the mrs,didnt really know anyone but roo,so we stayed for bit them went home,both heaps trashed from work :( ,keen to come along on cruse again,maybe if any random cruses happening next fri let me know,got few days off so keen to go out,otherwise try to get to calender days :) ,didnt check fri before going out,to see lil miss33 cruse maybe next time
Sorry man, I was too distracted looking at your car and catching up on chat ... I forgot to introduce you to the guys! I'm a rude a-hole :)
Next time you're out I'll give you a grand intro. :)
ah ok i remember seeing you at the lights when i was turning offf beach rd. nice car dude, youve got water in you inner brakelight passanger side :(
i went to pick up a mate before i went to kmart, thats why i was abit late.
Edited by Import S13
Next time you're out I'll give you a grand intro. :(
Dont stress it roo,we were tired and ready for bed anyways,u know how old i am :) haha,wont be able to get to karts on fri,il meet everyone soon enough,mainly come to show my new beast off,still trying to workout bugs
I dont think any sau people come out with me towards the bay on Anzac Highway because leaving at bp west tce we had like 5 cars and by the time we parked before the bridge near the bay i counted around 25 cars and still more skylines were parking and joining.
Had a wiked night, best unplanned cruise ive ever had!! After the bay we ended up going down lonsdale back to the city and around the place, great cruise... Really enjoyed it, thanks for the people who came.
ah ok i remember seeing you at the lights when i was turning offf beach rd. nice car dude, youve got water in you inner brakelight passanger side :rolleyes:
bugga! **runs outside to check this** haha
your car looks smick as, i had a closer look at villi's, love those rims!
Yeah was a good nyte let us know if ya plan on organising something again. :(
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
