Mid-week Meet-ups?
Sambo33gtst
 Share
Im up for a skyline meet why not... boostcruising meets or more P plater commonwhore meets are waste of time.
I think somewhere in the hoon laws says TARGETING BOOSTCRUISING MEETS.. lolz
But yea.. i've had my skyline for while and never ever seem to find fellow skyliners
  • Replies 146
Posted Images
Yeah sounds good about the pig 'n whistle funky, even if some people just have a few drinks while others eat some red meat, that'd be fine. And there is a vego menu as well:)
I was going to make the executive decision and make it a Wednesday night being that Thursday does seem to be the night for Police to come out with their defect bat...
We'll make the first one Wednesday next week which will give us time to round up a few more people, I'll post up the meet in the event section. (10th Sept 7.30pm)
Who is keen to have something at Pig N' Whistle @ Indooroopilly Shoppingtown? It has plenty of parking for everyone, close-ish to the City, and we could go for a run up Mt Coot-tha afterwards :P
lol sorry Kate...I'm quite well known amongst friends for missing the obvious, I'm sure you'll find out soon enough.
I'm keen to go anywhere tbh, I live at Kangaroo Point so I'm fairly central to anything/anywhere we want to go...but I do like going up into the mountains every now and again.
What about you...any spots that you're keen on? Where do you have to come from anyway?
+1 mountain cruises. :huh:
Kev,
i have been organising weekly M . Cruise . . . . i will see what is the weather like this thursday and also post up detail. . . if it is too wet then not a good idea to go up there.
cheers
stephen
I'll be up for some of these meets, by the looks I'm just around the corner form Kate, out towards ipswich.
The SAUQLD Agm is in a couple of weeks, so I'm sure the new events commitee will get some bigger events organised as well.
Would you guys be keen for a meet 'n greet first for coffee or food, then motor off for a cruise somewhere?
I think that would be ideal first so we can gauge what type of turn out we will get week to week....
I'm not too sure about a jolly's spin on a thursday night.
Last time I went up there on a thursday I was followed by popo. :huh:
Maybe tuesday or wednesday nights instead?
I think meeting at a food joint first is a good idea. :D
sounds fun, food and mountain cruise, 2 meet points perhaps before the main meet up, ie, one southside and one northside/city ish, i live pretty far south, ie: past park ridge but would still be interested.
(edited col)
 Share
    • What makes you say CD009 boxes are not as strong as you would think? I've always been told the last revision (CD00A) is good for 1000whp and I have no issue's believing it when comparing one side by side with an RB25 box. Makes them look tiny.
    • I picked up an open Center with shafts. I was told the Open shafts will fit a mechanical LSD and looking at them. I think they will work. Will update
    • The manual says a lot about the different ratios requiring different shafts. all the Centers are the same but depending on the ratio, this determines the shafts because different ratios need the center to be offset more or less or right to left.
    • those 2 sets of shafts will not interchange and if you’re lucky you haven’t damaged anything with all your pressing and bashing you said you’ve done
    • Freshly built stroked RB25/28. Motor runs great but consumes a lot more oil then It should. This summer with the heat I was consuming roughly a quart per 1800-2000kms. Now with the cold weather coming in, I'm consuming a quart per 1000kms which is no bueno. I had originally chalked this out to break in taking a little longer then it should, but I'm now around 4000km's on this engine. I think it's fair to say something isn't quite right. Here's the kicker, can't find what's causing it. I've also spoken to my engine builder and Precision Turbo and can't figure it out. Here's my train of thought on possible causes and what I've done.  Precision Turbo - I originally started thinking my oil pressure might be a tad too high for my 6466 Gen2. I took the center cartridge out, and while yes there's signs of oil on the turbine heatshield, it's very moderate. There's also very minor in/out play that concerns me. I sent pictures and videos to precision and they said the residue and in/out play is minimal and they doubt this is the issue. For piece of mind, I went ahead and installed a Turbosmart OPR V2 to bring oil pressure down. Made no difference. Precision is willing to take it in on RMA for an inspection and I'll probably take them up on that offer for peace of mind. BTW. Is it just me or does the turbines inducer's look clipped and not even between each other? I just noticed this now while posting and looking at the picture zoomed in. Might just be the picture...  Rings - Hot compression test and leak down test look good. Compression is 160 +-2psi across the board. I leak down at 16% on cyl 1,2,3,5,6 and 18% on cyl4. Keep in mind I have a snap on leak down tester and they read high (I.E, 15% on my wifes 2018 Sentra with 70000kms). Sparkplugs show minimal oil (Only #4 seems to have a tad). At a quart per 1000km's though, I would be expecting them to be wet. Here's the kicker, I run WMI. I'm thinking what if my compression rings are great, but I have an oil control ring issue on cyl4 and my WMI is steam cleaning the pistons and sparkplugs? I can still see the "Spool" logo on top of my CP pistons. The only time I see smoke out of the exhaust is in the high rpm/load range. So far, this is my main culprit. I'll probably turn off my WMI and go out with the car at spring pressure tomorrow and repull the plugs. Other thing that's strange though is that I have never seen any oil in my catch can. Thing is still dry after 4000kms. Cyl1 - Left, Cyl6 - Right. Valve seals - They're new and I would expect oil consumption on idle, first cold start or during decel. None of which is happening.  Crankcase pressure - I have 2x 10an valve cover lines to a vented catch can. Head drain and opened up internal oil drain paths. I also don't run E85. I've never seen any oil in my catch can. Doubtful this is causing any issues.  Rear main seal - I have no visible leaks, but figured maybe it was my rear main seal. After now having added 2-3 quarts, I would expect oil to leak out the bottom drain channel and/or my clutch to be slipping.  Let me know your thoughts. With winter coming and taking the car off the road until spring, I'm fine with pulling the motor apart but I would hate to take it all apart and the turbo was the issue in the end.
