Mid-week Meet-ups?
Sambo33gtst
 Share
  • Replies 146
Posted Images
i only bought it as a long motor so he will have to take out the old engine, rip the manifold and turbo etc all of it off and throw it on the new engine, put it in....
If he can beat $750 consider it his job.
cos its for my ceffy daily... too much effort to change a ceffy to manual, have to get a manual centre console and change the footbrake to a clutch and all that jazz.
just want an auto gearbox so I can pull out the old fucked one and put the new one in cheap cheap. ceffy's stock standard, and if I start modding it then it'll end up like my R32... 90% of its time spent at the workshop.
Hey everyone just a little FYI.
Phoned the pub/restaurant and they are expecting 20+ so a nice big table will be set for us :D
So on the night rock up in the outside bar at 7.30 for an 8.00pm dinner inside at the Fleet Street Restaurant!
Cheers,
Sambo
South Side Pre meet Point to be at Sunnybank Plaza around the back side of the carpark
Meet Between 6.30 and 6.50 to leave @ 7
will post pics of location
Post if you want to head over in a group from the south side so we know how many and if we have to wait for anyone
and my number is 0423612973 so call if you want to come and are going to be a little late
Thanks for organising that Damian, it's much appreciated mate :dry:
Just letting everyone know I have done a pretty much final edit of the attending list on the SAuQld Thread and have based the numbers from there on the size of our table for tomorrow night. So go on there and check it out, and please let me know if there are any changes, as I wont be making any on the day....
Clicky: http://www.sauqld.com/ipb/index.php?showtopic=1499
Reminder: If you think you may not find us, PM ME for my Mobile Number and call me on the night!11`` :(
 Share
    • Pretty simple question. I was about to put the transmission back in and thought I pretty much had it lined up when I noticed it seems like the pressure plate isn't flat. I was pretty careful when undoing the bolts both during initial disassembly for cleaning and when torquing them up for installation so this is pretty discouraging. I'm not sure if I accidentally bumped the pressure plate with the input shaft and bent it somehow or if it just showed up this way. Is it possible that there's just something obvious I'm not doing correctly? I'm pretty sure I was extremely careful to make sure the friction discs were seated correctly in the hub, everything lined up, flywheel torqued according to sequence, the little springs all sitting correctly in their seats, etc.  What's the play here? Do I jump straight to a new pressure plate?
    • OK. I can see that being the case. But if you live in the land of "only switching between 4.08, 4.11, 4.36" like most Skyliners, then you never encounter it. Now I perhaps understand why the crownwheel is thicker on some of the smaller numerical ratio diffs. The two stubs being the same (unequal) lengths and just swapped side to side between the different cases is a new one to me. I'm hating Nissan R200s more than ever now.
    • Reason I say this is I have seen broken ones, in drift, drag and even behind a stock Z. I do appreciate most of the time its the synchro's that go.   Trouble with quoting HP is it doesn't really say how strong the box is.  I've not seen many CD00X box's make it past a mid 9(150mph) I have seen about a stock R33 RB25 box's run a 9 too, they all go boom at some point though.   Another clue is they make gearsets for CD00X box's too, wouldn't be a market if they didn't break or have a limit people are going past.   I totally agree it is a strong box, just have to weigh up the true total cost of the conversion vs rebuilding with a good gearset.
    • What makes you say CD009 boxes are not as strong as you would think? I've always been told the last revision (CD00A) is good for 1000whp and I have no issue's believing it when comparing one side by side with an RB25 box. Makes them look tiny.
    • I picked up an open Center with shafts. I was told the Open shafts will fit a mechanical LSD and looking at them. I think they will work. Will update
