  • Replies 146
Posted Images
i only bought it as a long motor so he will have to take out the old engine, rip the manifold and turbo etc all of it off and throw it on the new engine, put it in....
If he can beat $750 consider it his job.
cos its for my ceffy daily... too much effort to change a ceffy to manual, have to get a manual centre console and change the footbrake to a clutch and all that jazz.
just want an auto gearbox so I can pull out the old fucked one and put the new one in cheap cheap. ceffy's stock standard, and if I start modding it then it'll end up like my R32... 90% of its time spent at the workshop.
Hey everyone just a little FYI.
Phoned the pub/restaurant and they are expecting 20+ so a nice big table will be set for us :D
So on the night rock up in the outside bar at 7.30 for an 8.00pm dinner inside at the Fleet Street Restaurant!
Cheers,
Sambo
South Side Pre meet Point to be at Sunnybank Plaza around the back side of the carpark
Meet Between 6.30 and 6.50 to leave @ 7
will post pics of location
Post if you want to head over in a group from the south side so we know how many and if we have to wait for anyone
and my number is 0423612973 so call if you want to come and are going to be a little late
Thanks for organising that Damian, it's much appreciated mate :dry:
Just letting everyone know I have done a pretty much final edit of the attending list on the SAuQld Thread and have based the numbers from there on the size of our table for tomorrow night. So go on there and check it out, and please let me know if there are any changes, as I wont be making any on the day....
Clicky: http://www.sauqld.com/ipb/index.php?showtopic=1499
Reminder: If you think you may not find us, PM ME for my Mobile Number and call me on the night!11`` :(
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
