I just spoke to Wally at Master cylinder exchange, Wynnum (QLD), and he said that he's got my master cylinder on the shelf, and that it would be $220 exchange. This is the place that all the people in my area send the master cylinders to for reconditioning, so i just figured that i'd cut out the middle man, as none of them would give me a concrete price. They all say between $250 and $450 and i didnt want to pay the latter.
His details are:
Master Cylinder Exchange, Wynnum
2/112 Glenora Street,
Wynnum, QLD 4178
Phone: (07) 3393 3188
yes thats correct
matching componentry is a must
my v spec has a factory 1 1/16 brake master on it because it has brembos where as normal gtr is 1 inch i think
Does you know where to get a v spec 1 1/16 m/c or an r33 1 1/16 with ABS (which seem to be the same) reading other threads?
OEM brake master cylinder kit for an R32 GTR is $85 USD. I don't know what it has in it but it says it's suitable for an 'overhaul'
http://www.rhdjapan.com/jdm/Nissan-OEM-Bra...line-GT-R-53712
Hope this helps.
I pulled mine off today and sent it to Qld. I couldnt be bothered searching high and low for a new one, so i just decided to get mine reco'd. At least it'll end up with a stainless steel bore!
  • 1 year later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
