Haha, like my title?
Does any one know where the G sensor is mounted on an R32 GT-R
I have flash codes:
11. G sensor 1 problem and,
13. G sensor 1, 2 or curcuit problem
from the ETS controller.
I need to know where the sensor is located so that I can test it.
Thanks
https://www.sau.com.au/forums/topic/233848-g-spot/
Well it's roughly in the middle, kind of up the top but a bit off centre and you have to poke around a little until you find it. Feedback from the owner is usually necessary... Hang on what are you talking about again? I forgot already.
https://www.sau.com.au/forums/topic/233848-g-spot/#findComment-4099383
LoL silliness; assuming you asked a serious question, its under the center console behind the hand brake.
All the screws that hold the console in are fairly straight forward and easy to see. Careful with the sensor unit (includes two latitudinal, one longitudinal) removal, Nissan quote about $3k.
https://www.sau.com.au/forums/topic/233848-g-spot/#findComment-4107629
    • I hope one day I can do it like you. Your engine looks great.
    • If there's nothing else I can do I'll probably do something like that Someone on the internet said that ca20s and ca18 engine blocks are the same and that you can use a ca20 engine block and put ca18det parts to make a ca20det Do you think this is possible or will it damage the engine?
    • Yeah, I did some research and found out that some things are different.
    • Makes sense, thanks! Consider me very impressed. And I very much appreciate the effort in documentating all of it. You'd be surprised, or maybe not, how many people this reaches who search for things online. Anyways, I shall continue to read all of it, understand maybe a quarter, and hope that some of it sticks if I ever end up in a situation where it's relevant
    • 'Did' work on them is more accurate ~ on the R31 Skyline forum, you can spot me as 'Solder'... I've written quite a bit about the 4R01 boxes there, and I ended up reverse-engineering the older TCU type operations, so we could fudge a custom TCU to pull off other tricks...and like all things, when you do it a lot, see the failure patterns, have to find parts etc etc, your head ends up filled with whys and wherefores... there was a reason Nissan went with these in more than 60models over 16+ years... all in all, the JR401E based design is an interesting study, as Nissan changed things over the years in a never ending battle against them lunching on themselves <grin>...by the time the RE4R01A rev.C came out (often referred to as RE4R01B), they'd more or less perfected the design...
