Hi,
Just noticed my 33 has a bit of a fuel leak after being able to smell it in a big way every time I filled up
after having a look underneath I can see that it is actually laking as I can see where it appears to have been fuel running down the tank and over all the rear suspension bits.
Question is, is it common for these tanks to crack at all? Im thinking highly unlikely although just wanted a bit of a heads up before i start pulling stuff apart. at this point im thinking its coming from the top screw cap that you open to get to the fuel pump.
Any ideas/experiences?
cheers
https://www.sau.com.au/forums/topic/233926-fuel-leak-r33/
I'd check the rubber o ring out that the fuel pump is under, and easy say 20 minute fix.
Also check around the filler cap area, when they comply the cars they have to install an ADR approved cap, some compliance guys just cut and shut but don't reseal. Check if your cap etc will spin if you twist it? If it does its just sitting there and neads resealing. Use a product called Sikaflex and it will reseal the compliance cap to the original filler neck. Its a urethane based product, so have heaps of rags handy and clean up with WD40. Don't use it on your o ring etc because once its set, you'll never get it apart again.
https://www.sau.com.au/forums/topic/233926-fuel-leak-r33/#findComment-4100560
Has anyone heard of fuel tanks cracking? thats my only stress at this point.. seals i can fix easy enough
Yeah, usually happens a) if a car has been off road and tank is slammed on roads of something b) as mentioned above if the car has been hit. c) older car
also I've heard of people drill holes in theirs by accident.
https://www.sau.com.au/forums/topic/233926-fuel-leak-r33/#findComment-4106875
  • 1 month later...
Having the same problem. Checked the O-ring and sure enough that needed replacing. That got back the woosh sound when opening the tank, however the smell and leak remained. So I jacked up the car to check where it was leaking from (since the filler neck showed no signs of leaking) and it appears to be leaking from where the filler neck meets the tank. Any advice would be much appreciated.
Thanks, Josh
https://www.sau.com.au/forums/topic/233926-fuel-leak-r33/#findComment-4202439
If its not structurally damaged, if it is still solid, I'd just use some tank sealer putty. You can get that at Repco or whatever, will work easy, just smear it on and push/work it in around the critical area. Its made for quick repairs on fuel tanks.
If its flexing and looks like it will get worse, its a tank out job. There are shops around that will weld a tank up, I 've done it before myself, you drain it, let it dry out, find a diesel motor and start it up, feed the exhaust fumes into the tank with a hose and while it is running, weld the tank up [mig is best, but oxy will work as well, arc is too much for the thin metal of a tank unless your a genius welder]. The exhaust fumes stop any big bang, they are carbon monoxide/dioxide plus other stuff and stop or supress any flame. A petrol engine will also work, but its not quite as safe. I've heard of guys using CO2 bottles as well.
An alternative to that is someone with a big soldering iron and solder it up. I've never seen fuel fumes ignite off a hot soldering iron. But soldered joints are not as strong as weld, but they can be pretty strong, many solder repairs have lasted years on fuel tanks and radiators.
A word of caution, its not for the novice [practice on something else] or the faint hearted, so if you can't weld don't try it yourself.
The last alternative is another tank, but who's to say it won't happen again.
https://www.sau.com.au/forums/topic/233926-fuel-leak-r33/#findComment-4202712
84ULP is the part number a cpc fuel cap. i think they are about $20 from your local auto store.
replacing the cap reduced the smell of fuel on my car, but still *shhhhhhhhhhhh* on a hot day. fuel does evaporate at a very low temp so i dont worry about it too much, worst things is having highly compressed fumes in your car and getting a static spark when u are fueling up, so losing approx 20ml of fuel through a non tight cap isnt much of a waste/risk.
btw how many kms do u get out of a full tank?
Edited by philta
https://www.sau.com.au/forums/topic/233926-fuel-leak-r33/#findComment-4207211
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
